jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,725 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I have the new 914Rubber air box seal and a new screen. Should the seal be glued to the air box with the screen mounted in the rubber seal?
And, any tips on this Attached thumbnail(s) ![]() |
hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 609 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
I have the new 914Rubber air box seal and a new screen. Should the seal be glued to the air box with the screen mounted in the rubber seal? And, any tips on this I did this on the pumpkin she is a 1970. I did not glue. I watched Ian Karr's video on this and it was great help. Rubber Bands to the rescue. |
jim_hoyland |
I have the new 914Rubber air box seal and a new screen. Should the seal be glued to the air box with the screen mounted in the rubber seal? And, any tips on this I did this on the pumpkin she is a 1970. I did not glue. I watched Ian Karr's video on this and it was great help. Rubber Bands to the rescue. Thanks, I watched Ian’s video. What size rubber bands do I need; and, where can I buy them ? Video : https://www.youtube.com/watch?v=Uhs6pedBOXM |
hndyhrr |
I have the new 914Rubber air box seal and a new screen. Should the seal be glued to the air box with the screen mounted in the rubber seal? And, any tips on this I did this on the pumpkin she is a 1970. I did not glue. I watched Ian Karr's video on this and it was great help. Rubber Bands to the rescue. Thanks, I watched Ian’s video. What size rubber bands do I need; and, where can I buy them ? Video : https://www.youtube.com/watch?v=Uhs6pedBOXM Id try the dollar store, they have an assortment bag. the ones I used were about maybe 1/2" wide and long. I read somewhere that if you loosen the supports on either side of where box goes it gives you a little more wiggle room. Once box is in just cut the rubber bands. oh and also it helps to have an extra set of hands for the install and don't forget to put the cable back on the bottom of box before you install that clip to hold the cable is a bitch to get on. Have a great long weekend. R. |
mgp4591 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,643 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region ![]() ![]() |
I have the new 914Rubber air box seal and a new screen. Should the seal be glued to the air box with the screen mounted in the rubber seal? And, any tips on this I did this on the pumpkin she is a 1970. I did not glue. I watched Ian Karr's video on this and it was great help. Rubber Bands to the rescue. Thanks, I watched Ian’s video. What size rubber bands do I need; and, where can I buy them ? Video : https://www.youtube.com/watch?v=Uhs6pedBOXM Id try the dollar store, they have an assortment bag. the ones I used were about maybe 1/2" wide and long. I read somewhere that if you loosen the supports on either side of where box goes it gives you a little more wiggle room. Once box is in just cut the rubber bands. oh and also it helps to have an extra set of hands for the install and don't forget to put the cable back on the bottom of box before you install that clip to hold the cable is a bitch to get on. Have a great long weekend. R. I've also used silicone lube to reduce the friction on the upper seal on the airbox...helps everything slide right into place. |
Lo-Fi Version | Time is now: 23rd May 2025 - 08:06 PM |
