sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 942 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,372 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
That's not a 914-6 line. That's for a 70s 911.
T.Rick6 |
Member ![]() ![]() Group: Members Posts: 56 Joined: 1-October 19 From: Douglasville, Ga Member No.: 23,512 Region Association: South East States ![]() ![]() |
I have an extra hard line if you need it for the -6, I'll attach pics later this afternoon if you're interested (IMG:style_emoticons/default/beerchug.gif)
Todd |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,866 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Attached image(s) ![]() |
gandalf_025 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,494 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States ![]() |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
ClayPerrine |
Word of warning.....if you use a maddog/rich johnson aftermarket motor mount for a six, the factory hard line won't work. The mount interferes with the location of the line.
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,572 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Word of warning.....if you use a maddog/rich johnson aftermarket motor mount for a six, the factory hard line won't work. The mount interferes with the location of the line. (IMG:style_emoticons/default/agree.gif) Use the mad dog oem style mount |
sixaddict |
Sorry guys …head in wrong place.
Y’all are correct…picture was of 911 hard line I was selling. This is for a factory six and just trying to see where it brackets mount to engine. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,839 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
That's not a 914-6 line. That's for a 70s 911. (IMG:style_emoticons/default/agree.gif) my six had that pipe as the motor was from late 71 911 2.2. |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,121 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Word of warning.....if you use a maddog/rich johnson aftermarket motor mount for a six, the factory hard line won't work. The mount interferes with the location of the line. (IMG:style_emoticons/default/agree.gif) Use the mad dog oem style mount I used the Maddog mount and a PMS oil line setup. mostly pleased with this |
ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,150 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
I was working on this VERY issue this evening,
I also do not have the attach point pictures and the factory manual does not show their placement in the pictures. I believe the one with the right angle attaches at the engine mount lower left (the mount over the pulley) and the other is attached to the engine case towards the front..... Unless someone else provide a picture I will get one that matches my guesses,,,,,,, |
sixaddict |
Long story as to why but I’m trying not to guess.
Good to know there’s no “easy answer. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,751 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Hey Terry Gandalfs picture shows the correct mounting hardware perfectly. The larger clamp on the left attaches to an 8mm stud on the right chain housing. The other clamp with the small 90 degree bracket attaches to the front engine tin in front of the left chain housing. Rory |
ctc911ctc |
Hey Terry Gandalfs picture shows the correct mounting hardware perfectly. The larger clamp on the left attaches to an 8mm stud on the right chain housing. The other clamp with the small 90 degree bracket attaches to the front engine tin in front of the left chain housing. Rory Rory, you are awesome, kinda figured this out - though - not quite sure, going to bolt it together now |
gandalf_025 |
930cabman |
better late than never, thanks for posting. this is great information (IMG:style_emoticons/default/aktion035.gif) |
sixaddict |
Thanks to all ….Finally found the pic I needed. (IMG:style_emoticons/default/beer.gif)
sixnotfour |
As per factory, the L bracket attaches to the sheet metal..
ctc911ctc |
Lo-Fi Version | Time is now: 4th June 2025 - 12:36 AM |
