oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,367 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
76 2.0, 130,000 miles. I used to run Brad Penn 30 with high ZDDP, a very “ sticky” oil. It stopped the little bit of smoking from the exhaust. (probably worn rings). The newer oil is called Penn oil, and I don’t think it’s the same as the original Brad Penn formulation. Now the engine is smoking a little again. Can anyone recommend a replacement/equivalent oil to my old stickyBrad Penn oil?
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,283 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Actually the old Brad Penn (green oil) was rebadged A DECADE ago as PENN GRADE 1, Same formulation. Other than your car smoking ...again, after 10 years Id say it seems to have held up pretty well?
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,455 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
I can't recommend an oil to help your car stop smoking, but I can say I moved from Brad Penn to Driven DT50 once the oil formula changed. I'll be moving to Driven GP-1 for my autocross car soon to better handle the heat soak it gets with 2 drivers.
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,337 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
I found if you remove you rear view mirrors it doesn’t smoke at all
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,942 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
You could try some of those magic sauces at the flaps, at 130000 it's gonna be smokey.
Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,985 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
I use Driven 15w/50w oil. You said your seeing smoke at the tail pipe. Do you need to add oil after so many miles to top off your oil? If so how much?
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,580 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Amsoil z rod is now my go to
oakdalecurtis |
I found if you remove you rear view mirrors it doesn’t smoke at all (IMG:style_emoticons/default/beerchug.gif) |
oakdalecurtis |
I’m thinking if trying Amsoiil zrod oil. I live in California with a warmer climate. Any opinion whether I should use 10-40 or 20-50 wt?
Artfrombama |
Member ![]() ![]() Group: Members Posts: 308 Joined: 21-January 24 From: Alabama Member No.: 27,870 Region Association: South East States ![]() ![]() |
Castrol 20W50 was the recommended air cooled oil for eons, I use the Brad Penn 20W50 synthetic blend
I remember asking an old VW mechanic years ago for a recommended brand; "Any clean oil is better than dirty oil". |
Literati914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,963 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
What's the important properties beside Zinc, that make you guys so dedicated to one brand or another?
I see some awfully cheap oils with significant zinc numbers. |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,140 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Castrol 20W50 was the recommended air cooled oil for eons, I use the Brad Penn 20W50 synthetic blend I remember asking an old VW mechanic years ago for a recommended brand; "Any clean oil is better than dirty oil". (IMG:style_emoticons/default/agree.gif) been using Castrol 20 50 for decades, never had a failure attributed to an oil issue |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,394 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
In olden times, people used crazy stuff like this.
Attached image(s) ![]() |
930cabman |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,157 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Artfrombama |
What's the important properties beside Zinc, that make you guys so dedicated to one brand or another? Good advertising! (IMG:style_emoticons/default/biggrin.gif) Seriously, I switched to Brad Penn because it was designed for older cars with flat tappet engines, at the time it was one of the very few on the market. |
Geezer914 |
Driven oil is recommended by Jake Raby. He helped develop this oil for 914's after Brad Penn changed formulas. I add 4 oz. of Marvel Mystery Oil to every other fill up to clean the injectors.. Mistery oil, it's a mystery how it works. (IMG:style_emoticons/default/lol-2.gif)
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 125,417 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
In olden times, people used crazy stuff like this. 3 . COMPOSITION / INFORMATION ON INGREDIENTS. Hazardous ingredients o-Dichlorobenzene (1,2-Dichlorobenzene (ortho-dichlorobenzene)) Fine White Mineral Oil Mineral Spirits 4. FIRST AID MEASURES Conc. 0 - 5% 70 - 100% 20 - 30% CAS 95-50-1 64742-52-5 8052-41-3 EINECS 202-425-9 265-155-0 Symbols/Risk phrases Xn; R22 Xi; R36/37/38 N; R50/53 Xn; R20/22 Xi; R36 R10 |
Lo-Fi Version | Time is now: 15th June 2025 - 02:42 PM |
