> Help with 6 heat exchanger mounting brackets
sixaddict
post Jun 14 2025, 09:10 AM
So finalizing engine details and need a little help with mounting brackets.
This picture shows mounting bracket in place.
The bracket on this side is MIA…maybe
Next is outboard…
Attached ImageAttached Image
Could some post what I should be seeing if correct. Zoom in on last pic and you can see outboard bracket. Trying to also determine where that attaches.
Thanks…..
Replies(1 - 11)
930cabman
post Jun 14 2025, 10:08 AM
I am not able to help with this, but it looks like things are coming together, keep it going
johnhora
post Jun 14 2025, 11:17 AM
TOT...don't think there's a mounting tab on that side..the one on the dr side has the tab that the clamp for attaching the speedo, clutch, and throttle cables is also connected
johnhora
post Jun 14 2025, 11:18 AM
here's another pic of OEM HE's
sixaddict
post Jun 14 2025, 12:22 PM
They are…..we ( builder and I) better known as technician and financier, plan to build engine stand as he would like to hear results of labors plus we can be sure all is well.
Thanks for noticing…
quote name='930cabman' date='Jun 14 2025, 08:08 AM' post='3210205']
[/quote]
sixaddict
post Jun 14 2025, 12:24 PM
John…
Thanks exactly what I was hoping for…..great pics!
Thank you.
Terry
fixer34
post Jun 14 2025, 01:33 PM
Yes, I believe the tab on the one side is to clamp the cables in place, not mount to the case.
On a different note, I see you installed turbo valve covers on the exhausts. If you ever plan to check/adjust the valves with the engine in the car (and bolted up) you need to mill/shave some of the fins around a couple bolts. Otherwise they won't clear the trailing arm frame mounts. There are a couple threads about it.
Ask me how I know..
sixnotfour
post Jun 14 2025, 08:49 PM
Brackets..
porschetub
post Jun 14 2025, 09:57 PM
QUOTE(fixer34 @ Jun 15 2025, 07:33 AM) *
Ask me how I know..
(IMG:style_emoticons/default/agree.gif) why would want to solid mount to the HX on to the case ? but why it perfectly lines up on that case stub has got me baffled ??? .
Pretty sure OP knows about the lower rocker covers ,cheers.
porschetub
post Jun 14 2025, 10:42 PM
[quote name='porschetub' date='Jun 15 2025, 03:57 PM' post='3210274']
[quote name='fixer34' post='3210221' date='Jun 15 2025, 07:33 AM']
Ask me how I know..
[/quote]
Edit ,great pics supplied sixer ,confirms than bracket isn't there in that bunch of tressures you have ?? ,rest look like lower tin fitment ...think so as they are 6mm.
Cheers.
mb911
post Jun 15 2025, 04:34 AM
Terry are you still having the debate on the heat exchangers? Just one tab on that side and then the z bracket on the other side
sixaddict
post Jun 15 2025, 09:33 AM
QUOTE(mb911 @ Jun 15 2025, 02:34 AM) *
Yes kind of……..not sure I know what you mean on Z bracket….i see a bracket on outboard side and assume it must attach to something.
On valve covers ……will be changed before installing in the car…..but have a set of original look alikes ( SC) that are aluminum and purportedly won’t leak. (IMG:style_emoticons/default/dry.gif) vs magnesium originals. Now to find them.
2 User(s) are reading this topic (1 Guests and 1 Anonymous Users)
- Lo-Fi Version Time is now: 15th June 2025 - 02:55 PM
