Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,243 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Engelbert designed a solution for the 911 to allow the rear turnsignal to double as brake lights for a larger brake footprint. I believe he is planning to market it for the 911 guys. Because of the layout of the 911 rear light housing, to install the module in the housing, the housing has to be removed and opened up.
I thought this would work well for the 914 and should be easy to install as access to the rear housing and wires is in the trunk. Engelbert was ok with me basically copying his solution. Here's a link to his 911 solution: rothaus (Engelbert) 911 RTS to Brakes The RTS-Brake module would reside below each rear light housing. One for each side. Here's the module being tested on the bench. https://www.youtube.com/watch?v=i5h_pG7AQ9A The module has 6 wires. Brake-in, Brake-out, RTS-in, RTS-out, and 2 grounds. The wires have QC connectors and go between the OEM wiring and the light housings. ![]() The IN wires have male connectors and the OUT wires have female connectors. ![]() On each side, pull the brake, RTS, and GND wires from the housing. The wires connect to the IN wires and the OUT wires goes to the housing. On my '71, the RTS QC connectors don't have insulation so a short piece of heat shrink provides the insulation. ![]() Once the RTS connectors are insulated, pull one wire at a time and install. ![]() ![]() Here are the modules in action on my 914. My 914 is set up to always have the running lights on with the ignition. https://www.youtube.com/watch?v=RHFrilGntQM I built an extra set if someone would like to try them out. If folks are interested, I'll be selling these for $45/pair. |
FlacaProductions |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,029 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
Hey Jerry - of course I'd love to try em out but I'm a few weeks away from being back with the 914. So....if you provide a link, I'm all in on these. You can't have too much light on these little cars!
slowrodent |
Member ![]() ![]() Group: Members Posts: 205 Joined: 29-February 20 From: Tucson/Oro Valley Member No.: 23,981 Region Association: Southwest Region ![]() ![]() |
Very very practical and very good looking.... Looks as if I'd better start saving a few $$$ up soon. (IMG:style_emoticons/default/idea.gif)
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,066 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Your products (and support) are always top notch.
2 pairs please. |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,432 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Boy... I run the Euro rear lenses on my 6 but really like the idea of adding more light when stepping on the brake pedal. I will have to think about this as I love all things Spoke Works which make our cars, in my humble opinion, much safer on the road. (IMG:style_emoticons/default/beerchug.gif)
Spoke |
Your products (and support) are always top notch. 2 pairs please. @mepstein Mark, Sounds good. I'll have these in the mail tomorrow. I don't have any 1/4 heat shrink tubing on hand for the RTS connector if it is bare like my '71. I used a 1 inch piece for each side. Electrical tape would do in a pinch. Please PM your address. |
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,749 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
I will also be in for a set.
When can we place an order? |
Spoke |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,591 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
Great idea, I’ll have to add to my parts stash
Spoke |
Here's a connection diagram for these RTS-Brake modules. Connecting these modules is straightforward. Pull one wire at a time and plug the OEM wire into the corresponding module wire color and wire color to the housing.
![]() All the connection information and OEM wire colors were used from Jeff Bowlsby's diagram: ![]() |
ValcoOscar |
Garage Life ![]() ![]() ![]() ![]() Group: Members Posts: 2,535 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California ![]() ![]() ![]() |
Just terrific...
I'm in for TWO(2) sets. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer3.gif) DONE....PAID Thx O |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,874 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Nice upgrade Jerry, I’ll order a set (IMG:style_emoticons/default/smile.gif)
PM sent re address correction, send to PO Box 901 …. @Spoke |
gonzo54 |
Orange Crush ![]() ![]() Group: Members Posts: 272 Joined: 10-May 19 From: Seal Beach, CA Member No.: 23,112 Region Association: Southern California ![]() ![]() |
@Spoke , I have your LED Brake Boards on my car but have not upgraded to the LED turnsignal boards. Will this mod work with my incandescent turn signal bulbs or will I need to upgrade to LED?
Thanks-Rick |
Spoke |
@Spoke , I have your LED Brake Boards on my car but have not upgraded to the LED turnsignal boards. Will this mod work with my incandescent turn signal bulbs or will I need to upgrade to LED? Thanks-Rick Yes it should work. These are 2Amp relays and the 1056 21W bulbs should only draw about 1.8Amp. It is close but should work. |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,034 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Do I see piggyback terminals on the left side housing connections? If so, are they needed?
Spoke |
Do I see piggyback terminals on the left side housing connections? If so, are they needed? Good eye. I didn't want to comment on that just to keep things simple. The piggyback connector is for my 3rd brake light on the roll hoop. I steal brake power from this pin. Here's a description of my 3rd brake light install: 3rd Brake Light Install |
Stratfink |
Member ![]() ![]() Group: Members Posts: 83 Joined: 27-December 21 From: SoCal Member No.: 26,198 Region Association: Southern California ![]() ![]() |
Ordered this morning along with the brake, turn signal and reverse light boards!
Spoke |
With a simple jumper, the brake can also function as turnsignal/brake. This works only for LED brake and turnsignal because of the high current of incandescent bulbs.
![]() Here's a video of the RTS-Brake with the brake also doubling as the RTS. https://www.youtube.com/watch?v=fu5en-uRFaE |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,909 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Very nice product! (IMG:style_emoticons/default/driving.gif)
Just to be clear, on the combined turn signal/brake setup (video in post 18), what happens when you hit the brakes with the turn signal on, does the turn signal splits back from the brake so you still have a brake light on next to the flashing light? In your first video, you had EU lenses with red LEDs in the back. Always difficult to see the shade of the light on camera. Was there a big difference betwheen the red of the brake lens portion and the red through the amber portion? If not, could the turn signal board be populated with both red and amber LEDs to serve as two functions? (IMG:style_emoticons/default/idea.gif) I definitely love the idea of having more brake lights, but I want to keep my EU lenses and amber turn signal. Looking at buying your products but since I am not about to drive my car (IMG:style_emoticons/default/rolleyes.gif) , I am sort of waiting for the ever going product improvement and selection. (IMG:style_emoticons/default/smilie_pokal.gif) |
Cairo94507 |
Great question by Montreal914. I would love to do this modification, but love me EU rear turn signals. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 13th September 2025 - 02:43 AM |
