timgreen |
Newbie ![]() Group: Members Posts: 4 Joined: 30-March 09 From: West Chicago, IL Member No.: 10,219 Region Association: Upper MidWest ![]() |
I am selling my 1974 914-6 race car known as POLIZEI - $30,000 OBO
Original SCCA car from Pennsylvania (roll bar number 31-028) ENGINE: 2.7L from ‘76 911, upgraded to 275HP Race prepared Weber duel 3-barrel carburetors, dual plug heads Electromotive crank-fire ignition Custom J&E 11:1 compression pistons 911 turbo oil pump Oversized valves, heads prepared by Werner Machine JWE (Jerry Woods) performance cams similar to GE-40) 911 and large Fram oil filter Engine built and dyno’d by CS Motorsports Rich Johnson engine mount Cable accelerator Centerforce racing clutch with hydraulic actuator Streb oil cooler Peterson 4 gallon oil tank AN-16 & AN-20 oil lines TRANSMISSION: 901 side shifter transmission (1975) with custom gears (A,F,M,S,X) Quaife limited slip 7/31 ring & pinion Trans oil cooler with electric pump Custom 915 style shifter with reverse lockout Hydraulic clutch 930 turbo CV joints SwayAway custom axles SUSPENSION: Rich Johnson drop spindles with coil over modification Custom trailing arm modification for better control Koni double adjustable shocks Custom front sway bar CUSTOM DASH: (Autometer gauges) 10,000RPM Tachometer with shift light Oil pressure Oil temperature Trans oil temperature Fuel pressure Battery voltage 30psi oil warning light BRAKES: Tilton brake and clutch pedals w/ remote Revisor Wilwood 6-piston front and 4-piston rear racing calipers BODY: Safe door cage Updated front bars Baker nose & fenders Fiberglass hood Lightened doors Lightened trunk Fuel Safe fuel tank Custom seat ![]() |
Lo-Fi Version | Time is now: 19th June 2025 - 08:13 AM |
