curt |
Newbie ![]() Group: Members Posts: 14 Joined: 16-March 08 From: Lompoc, CA Member No.: 8,821 Region Association: None ![]() |
Hi Everyone
looking for front sway bar drop link to front control arm torque spec. I have seen everything from 18 lbs to 33 lbs. Or I am just not understanding what I am reading. Help...thanks! Curt |
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,345 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
Puebloswatcop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,566 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region ![]() |
Hi Everyone looking for front sway bar drop link to front control arm torque spec. I have seen everything from 18 lbs to 33 lbs. Or I am just not understanding what I am reading. Help...thanks! Curt Hi Curt, I looked in the Porsche shop manual and it does not give a torque spec. for the end links. So just using a standard torque spec table this is what I came up with. The strength class should be on the head of the bolt. Those are M8 bolts. If its an class 8.8 its 18 ft pounds, if its a class 10.9 it is 26 Ft. Pounds and if it is a class 12.9 then it should be 31 Ft. Pounds. |
curt |
Hi Everyone looking for front sway bar drop link to front control arm torque spec. I have seen everything from 18 lbs to 33 lbs. Or I am just not understanding what I am reading. Help...thanks! Curt Hi Curt, I looked in the Porsche shop manual and it does not give a torque spec. for the end links. So just using a standard torque spec table this is what I came up with. The strength class should be on the head of the bolt. Those are M8 bolts. If its an class 8.8 its 18 ft pounds, if its a class 10.9 it is 26 Ft. Pounds and if it is a class 12.9 then it should be 31 Ft. Pounds. Thank You...very much appreciated....Curt |
Puebloswatcop |
Hi Everyone looking for front sway bar drop link to front control arm torque spec. I have seen everything from 18 lbs to 33 lbs. Or I am just not understanding what I am reading. Help...thanks! Curt Hi Curt, I looked in the Porsche shop manual and it does not give a torque spec. for the end links. So just using a standard torque spec table this is what I came up with. The strength class should be on the head of the bolt. Those are M8 bolts. If its an class 8.8 its 18 ft pounds, if its a class 10.9 it is 26 Ft. Pounds and if it is a class 12.9 then it should be 31 Ft. Pounds. Thank You...very much appreciated....Curt Sorry I couldn't get the exact spec from Porsche, they just say torque to spec, but then don't list a spec....go figure. |
Puebloswatcop |
Lo-Fi Version | Time is now: 1st July 2025 - 06:32 PM |
