> Drivetrain Woes
gfg3
post Jun 22 2025, 07:49 AM
Never Too Old
My '75 1.8 has developed a vibration when in 5th gear. All other forward gears and reverse work just fine. Am I looking at tearing the trans apart or maybe a CV joint?
Thanks.
George
Replies(1 - 8)
jim_hoyland
post Jun 22 2025, 07:58 AM
Get that VIN ?
Is the vibration constant at various RPMs ? Does it dissipate at say 4K ?
mlindner
George, under load in 5th, decelerating, coasting at speed in nuetral?
gfg3
post Jun 22 2025, 10:21 AM
Never Too Old
Seems constant under constant load plus accel & decel. Coasting it goes away. Also goes away when I downshift into 4th.
gfg3
post Jun 24 2025, 07:35 AM
Never Too Old
Any ideas, folks? I'm really baffled about this and don't want to tear out the trans unless I have to.
George
Shivers
post Jun 24 2025, 07:49 AM
QUOTE(gfg3 @ Jun 24 2025, 06:35 AM) *
George
Sounds like a good time to paint your drive axles and inspect and lube your CV's. If you find a bad one problem solved, if not you know where you need to look next and the axles are already out of the way. I hope it is a bad CV.
Cairo94507
post Jun 24 2025, 11:11 AM
Michael
CV's are my first thought too. (IMG:style_emoticons/default/beerchug.gif)
dr914@autoatlanta.com
post Jun 24 2025, 11:21 AM
yes maybe the cv axle
QUOTE(gfg3 @ Jun 22 2025, 06:49 AM) *
Thanks.
George
gfg3
post Jun 25 2025, 09:50 AM
Never Too Old
Thanks everyone. Once the temps get below the high-90s here in Virginia, I'll slide under the car and take a look.
George
- Lo-Fi Version Time is now: 1st May 2026 - 03:16 AM
