> Front Shock Mount Frustration
DennisV
post Jun 24 2025, 07:51 PM
I thought I would post this to possibly save someone else frustration, or alternatively uncover something stupid I might have done.
I had a really tough time installing our new Boge front struts in the a set of new 2-piece mounts. In short, I couldn’t get enough of the strut thread above the bushing to start the nut.
It turned out it was a couple compounding issues:
1. The contour of the top portion doesn’t allow the support washer to seat as far down as original. There is a few mm gap between the washer and the metal insert.
2. When mating the top and bottom halves, even with maximum force applied, they are separated by the body which increases the total distance.
I ultimately took a Dremel to change the profile on the top in order to get the washer to sit low enough to get the nut started on the thread. Disappointing to troubleshoot and rework a new $235 part.
It is a clever design, and if I’ve done something stupid let me know. I couldn’t find another way to get the strut on.
I checked original vs new and found about 6 mm total difference in height. What was more important was the washer offset.
FWIW - I checked the strut thread length and it was the same on my old Koni and new Boge. So the strut was not the issue.
Replies(1 - 8)
rjames
post Jun 24 2025, 08:11 PM
I'm made of metal
A significant difference. I almost went with new mounts when I replaced my struts last year, but found mine were in great shape. Glad I didn’t. More QC or design issues. Replacement parts should just fit unless otherwise noted by the manufacture.
Superhawk996
post Jun 24 2025, 08:32 PM
QUOTE(rjames @ Jun 24 2025, 10:11 PM) *
The struggle is real! (IMG:style_emoticons/default/headbang.gif)
post Jun 25 2025, 03:38 AM
914-6 GT in waiting
Who made the replacement
bdstone914
post Jun 25 2025, 04:58 AM
bdstone914
QUOTE(mepstein @ Jun 25 2025, 02:38 AM) *
Pretty sure i know who made them as i have a pair just like that I never used when i saw the poor design. Return them and buy another supplier. Elephant Racing, amoung others, makes them too.
Be carefully as the 914 strut bearing housing is a different profile then the 911 even though they are the same profile. Elephant had a problem early on and corrected it.
DennisV
post Jun 25 2025, 08:15 AM
I got them from Elephant about 2 years ago.
post Jun 25 2025, 09:22 AM
914-6 GT in waiting
QUOTE(DennisV @ Jun 25 2025, 10:15 AM) *
So are the strut top mounts 911 since it’s from a six?
DennisV
post Jun 25 2025, 09:33 AM
QUOTE(mepstein @ Jun 25 2025, 08:22 AM) *
Per the PDF parts catalogs, that part number (911 341 018 00) for supporting mount (the metal and bushing combined) is the same for 914, 914-6, and '70-89 911. Same for the support washer (901 341 629 00) that I was not getting to fully seat.
bdstone914
post Jun 25 2025, 12:49 PM
bdstone914
QUOTE(DennisV @ Jun 25 2025, 07:15 AM) *
Call them and exchange for the updated version
- Lo-Fi Version Time is now: 7th July 2025 - 04:59 AM
