> Various Tool Recommendations
Cfletch
post Jun 25 2025, 05:53 PM
Hey there everyone! I am looking for a few tool recs from fellow users. I need to start worrying about a few tools for the car and am looking for tips on which to buy from those who have already gone through the process.
Tools I need:
Bubble Flare brake line tool. I need one for a custom line made to go from my rear tunnel 90 degree fitting to my "T" for the rear brakes. I have a cheapo one that makes horrible bubble flares. Looks like the sky is the limit on a tool like this price wise, but I need just 1 line made so ideally I do not spend a ton just for that.
Front shock tool: I think I have Boge struts and suspect I need some special tool for removing the top cap to pull the inserts out? Any suggestions there?
Lower Ball Joint socket. Again, not looking to spend an arm and a leg, but will need a socket for the lower ball join on the front suspension for tightening and loosening the component.
Any links or names or even rentals would be appreciated!
Thank you
Replies(1 - 7)
DennisV
post Jun 25 2025, 06:03 PM
QUOTE(Cfletch @ Jun 25 2025, 04:53 PM) *
Front shock, I just put it in a vice that had plastic jaw inserts.
Ball joint socket, I highly recommend Jimmy Tidwell. Excellent tool, and great person to deal with.
930cabman
post Jun 25 2025, 06:25 PM
lower ball joint - I have done this operation a couple times, a largeish pipe wrench got er done
post Jun 25 2025, 06:52 PM
914-6 GT in waiting
Buy the tool from jimmy t. The quality makes it easily worth the money and jim is a great guy to deal with.
Gland nut - I use a pipe wrench if I’m removing the gland nut and installing a new one. I use a bicycle lock ring tool to tighten the new one.
bkrantz
post Jun 25 2025, 07:48 PM
Don't cheap out on the ball joint socket. Stripping the nut and/or not getting it tight would be a bad thing.
rjames
post Jun 25 2025, 08:27 PM
I'm made of metal
QUOTE(bkrantz @ Jun 25 2025, 06:48 PM) *
Get the one Jimmy sells. And use new ball joint nuts. They are cheap, and yours are likely already beat up by the previous owner. Given their high torque spec, if yours are marred in any way, it’s unlikely you’ll be able to tighten them enough without the tool sliding off.
Cfletch
post Jun 26 2025, 12:12 PM
Ordered the socket tool from Jim! Much cheaper than the other listings I can find online which is great! Anyone have suggestions on the brake line flare tool?
930cabman
post Jun 26 2025, 01:49 PM
QUOTE(Cfletch @ Jun 26 2025, 12:12 PM) *
I have an old NAPA flare tool, getting the bubble can be tricky, but works well for me
- Lo-Fi Version Time is now: 7th July 2025 - 05:07 AM
