friethmiller |
Senior Member ![]() ![]() ![]() Group: Members Posts: 936 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region ![]() ![]() |
Does anyone know the height of the lettering used for the chassis number in the trunk? Or, could measure it, please? I'm trying to replicate the Karmann number on my LE but this trunk was replaced by the PO. I have a 4mm, 6mm, and 10mm punch set. So, it'll probably be 8mm (IMG:style_emoticons/default/blink.gif)
![]() Thanks. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,414 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
The original trunk floor is still in Elwood, so I will measure them after work and get back to you asap.
friethmiller |
Jamie |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,124 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States ![]() ![]() |
Does anyone know the height of the lettering used for the chassis number in the trunk? Or, could measure it, please? I'm trying to replicate the Karmann number on my LE but this trunk was replaced by the PO. I have a 4mm, 6mm, and 10mm punch set. So, it'll probably be 8mm (IMG:style_emoticons/default/blink.gif) ![]() Thanks. They are 10mm in my original 1973 teener. (IMG:style_emoticons/default/aktion035.gif) I haven't seen them in years and didn't realize they were that big! |
friethmiller |
They are 10mm in my original 1973 teener. (IMG:style_emoticons/default/aktion035.gif) I haven't seen them in years and didn't realize they were that big! Sweet Jesus! What luck! Thanks, Jamie! Clay, Interested if you can confirm this, as well. (IMG:style_emoticons/default/beerchug.gif) A pic could probably help as well. Hard to see in the above photo that I pulled from an very old thread. Thanks! |
ClayPerrine |
Puebloswatcop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,555 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region ![]() |
Fred, you should have known they were 10 mm. They were thinking of us at our age and wanted to be sure we could read them.....LOL (IMG:style_emoticons/default/lol-2.gif)
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,854 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
One question could be: what is the width? (IMG:style_emoticons/default/idea.gif)
friethmiller |
I just walked out into the garage and took this: ![]() Funny.. I work with LOTS of metric stuff all the time, but all of my tape measures are in inches. It is about 3.8 of an inch, which is 9.5 mm. But it was an eyeball and tape measure thing, so I figure 10 mm is right. Clay, what year is Elwood? Your chassis number appears to be located in the middle - not to the pass. side by the sway bar reinforcement tab. Interesting (IMG:style_emoticons/default/huh.gif) Can anyone else post pictures of their trunk numbers. My chassis number is 7 digits. Are all 7 stamped? |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,138 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,769 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
I just walked out into the garage and took this: ![]() Funny.. I work with LOTS of metric stuff all the time, but all of my tape measures are in inches. It is about 3.8 of an inch, which is 9.5 mm. But it was an eyeball and tape measure thing, so I figure 10 mm is right. Clay, what year is Elwood? Your chassis number appears to be located in the middle - not to the pass. side by the sway bar reinforcement tab. Interesting (IMG:style_emoticons/default/huh.gif) Can anyone else post pictures of their trunk numbers. My chassis number is 7 digits. Are all 7 stamped? I think Clays pic shows the 914 6 placement ...and number |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,288 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
This is the 1970 location, and the 1970 914/6 series # with the year position missing.
ClayPerrine |
Apparently the number on the six chassis was stamped in a different location.
There is surface rust obscuring some of the letters. I am hesitant to take it off. |
friethmiller |
Well I won't call it a complete failure but....
![]() It's not easy to get a hammer in here and get the numbers straight. I used a piece of tape as a bottom line, which helped but I couldn't hit with enough force to really make a good imprint. Probably needs to be done before the piece goes in the car. (IMG:style_emoticons/default/confused24.gif) If I can't get something behind it to actually imprint the numbers better, I may abandon the effort. I'm thinking I might use a bottle jack and some wood blocks to provide support from underneath. If so, I'll grind/hammer what I did and start over. |
Jamie |
Well I won't call it a complete failure but.... ![]() It's not easy to get a hammer in here and get the numbers straight. I used a piece of tape as a bottom line, which helped but I couldn't hit with enough force to really make a good imprint. Probably needs to be done before the piece goes in the car. (IMG:style_emoticons/default/confused24.gif) If I can't get something behind it to actually imprint the numbers better, I may abandon the effort. I'm thinking I might use a bottle jack and some wood blocks to provide support from underneath. If so, I'll grind/hammer what I did and start over. They should be oriented East/West, not North/South to be like original. (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 1st July 2025 - 04:24 AM |
