hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 624 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
Evening all, I had the Pumpkin up on a jack stand (pass side) to disconnect fuel lines to pull the gas tank (yet again). When I put her back on the floor she is leaning lower on the drive side. What should I look for or do? Tried bouncing front pass side and it did nothing. Help please. Thanks Renee |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,954 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Shocks, strut inserts go bad over time. Springs loose their spring.
hndyhrr |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,873 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Evening all, I had the Pumpkin up on a jack stand (pass side) to disconnect fuel lines to pull the gas tank (yet again). When I put her back on the floor she is leaning lower on the drive side. What should I look for or do? Tried bouncing front pass side and it did nothing. Help please. Thanks Renee Roll the car forward and back and it will settle, mines like that and always settles back level ,see how you go ,cheers. |
hndyhrr |
Evening all, I had the Pumpkin up on a jack stand (pass side) to disconnect fuel lines to pull the gas tank (yet again). When I put her back on the floor she is leaning lower on the drive side. What should I look for or do? Tried bouncing front pass side and it did nothing. Help please. Thanks Renee Roll the car forward and back and it will settle, mines like that and always settles back level ,see how you go ,cheers. Thank you |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
If you raised the passenger side, look for things that have become displaced. In particular, if you have aftermarket springs on the rear, they may have popped out of the spring perches.
--DD |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,422 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Lo-Fi Version | Time is now: 3rd July 2025 - 11:56 PM |
