cassmcentee |
Member ![]() ![]() Group: Members Posts: 228 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California ![]() ![]() |
Tom1394racing |
Member ![]() ![]() Group: Members Posts: 457 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States ![]() ![]() |
The clutch pedal backstop needs to be adjusted so the arm does not contact the PP when the pedal is fully depressed.
cassmcentee |
The clutch pedal backstop needs to be adjusted so the arm does not contact the PP when the pedal is fully depressed. I wasn't aware of a backstop, thank you Tom, figure I need to weld some meat back into the arm as well. (IMG:style_emoticons/default/welder.gif) |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,299 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
The clutch pedal backstop needs to be adjusted so the arm does not contact the PP when the pedal is fully depressed. I wasn't aware of a backstop, thank you Tom, figure I need to weld some meat back into the arm as well. (IMG:style_emoticons/default/welder.gif) Wouldn't that be when the clutch pedal is fully released? The arm at that spot would move away from the pressure plate when the pedal is depressed. |
BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 674 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
The clutch pedal backstop needs to be adjusted so the arm does not contact the PP when the pedal is fully depressed. I wasn't aware of a backstop, thank you Tom, figure I need to weld some meat back into the arm as well. (IMG:style_emoticons/default/welder.gif) Wouldn't that be when the clutch pedal is fully released? The arm at that spot would move away from the pressure plate when the pedal is depressed. Yes, @fixer34 is correct -- the release arm is dragging on the pressure plate when the clutch pedal is up. My guess is that someone put a thick washer (or a couple of washers) under the pivot ball, moving the release arm too close to the pressure plate, causing the arm to rub on the pressure plate when the clutch is released. Usually the pivot ball is spaced out only when the flywheel is machined, to take up the extra space caused by the clutch face being moved forward (due to the machining). Did you or someone put a new flywheel on the engine recently? If so, I'm guessing y'all forgot to check the pivot ball for washers. |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,600 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
The clutch pedal backstop needs to be adjusted so the arm does not contact the PP when the pedal is fully depressed. I wasn't aware of a backstop, thank you Tom, figure I need to weld some meat back into the arm as well. (IMG:style_emoticons/default/welder.gif) Wouldn't that be when the clutch pedal is fully released? The arm at that spot would move away from the pressure plate when the pedal is depressed. Yes, @fixer34 is correct -- the release arm is dragging on the pressure plate when the clutch pedal is up. My guess is that someone put a thick washer (or a couple of washers) under the pivot ball, moving the release arm too close to the pressure plate, causing the arm to rub on the pressure plate when the clutch is released. Usually the pivot ball is spaced out only when the flywheel is machined, to take up the extra space caused by the clutch face being moved forward (due to the machining). Did you or someone put a new flywheel on the engine recently? If so, I'm guessing y'all forgot to check the pivot ball for washers. Question wouldn’t you hear that? |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,877 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Bens comment (IMG:style_emoticons/default/agree.gif) ,the noise must have been very noticeable ,clutch/flywheel appear new but pressure plate appears to be a non branded one ? from what I can see anyway ,my point being is it the correct OEM fit and how long has it been on your motor?.
Agree with other comments about shimmed pivot ball bolt ,cheers. |
fixer34 |
Bens comment (IMG:style_emoticons/default/agree.gif) ,the noise must have been very noticeable ,clutch/flywheel appear new but pressure plate appears to be a non branded one ? from what I can see anyway ,my point being is it the correct OEM fit and how long has it been on your motor?. Agree with other comments about shimmed pivot ball bolt ,cheers. Look very closely at the second picture, the throwout bearing 'ring' on the pressure plate fingers doesn't seem to be even. Maybe the picture, some of the fingers aren't even. I think that pressure plate is still suspect. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,773 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Whole lotta crank end play ? Is the car new to you ? was it OK till some change ? |
Tom1394racing |
The clutch pedal backstop needs to be adjusted so the arm does not contact the PP when the pedal is fully depressed. I wasn't aware of a backstop, thank you Tom, figure I need to weld some meat back into the arm as well. (IMG:style_emoticons/default/welder.gif) Wouldn't that be when the clutch pedal is fully released? The arm at that spot would move away from the pressure plate when the pedal is depressed. Yes...You guys are right. I was thinking of my 911 experience with the 911/01 type of clutch. |
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,100 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
My guess is that someone put a thick washer (or a couple of washers) under the pivot ball, moving the release arm too close to the pressure plate, causing the arm to rub on the pressure plate when the clutch is released. Usually the pivot ball is spaced out only when the flywheel is machined, to take up the extra space caused by the clutch face being moved forward (due to the machining). Did you or someone put a new flywheel on the engine recently? If so, I'm guessing y'all forgot to check the pivot ball for washers. This would be my first guess as well as I cant think of anything else that would move that part of the arm closer to the pressure plate. The pressure plate itself does look a little odd though to me. Thinking about it a bit Stepping on the clutch pedal would pull that part of the arm away from the plate, so the contact is occurring while the clutch is not depressed. The only way I could see contact occurring in this state is if the throw-out bearing arm was at a very extreme angle while at rest, however when shimming the pivot ball to obtain this angle what eventually happens is the TO bearing arm winds up hitting the case (not the pressure plate). So im thinking either the thickness of the bearing is to thin or for some reason the pressure plate is to thick. that appears to be a fairly large interference where there should be a gap so I wouldnt imagine its crank float, but who knows? |
Lo-Fi Version | Time is now: 7th July 2025 - 12:02 AM |
