| ctc911ctc |
Jul 7 2025, 07:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,398 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
1970 914-6, all original
All Teeners Yea I get it, we teeners are special - very special. And, considering this little fact so are the prices of the most benign little part. The webbing for the oil tank hoses on my 914-6 are a bit frayed and I went to source some and - YOW!! If anyone has a reasonable source or is hording hose, let me know, spending 600+ on oil hoses......well, just seems a bit TOO SPECIAL. (IMG:style_emoticons/default/dry.gif) Read the quotes at the various sites carefully, they lull you in with 58.00 and then when you get ready to order the price is PER FOOT! (IMG:style_emoticons/default/mad.gif) |
| Superhawk996 |
Jul 7 2025, 08:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,189 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
| live free & drive |
Jul 7 2025, 08:44 PM
Member ![]() ![]() Group: Members Posts: 218 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None
I think you want the series 2633 it's slightly cheaper too:
https://belmetric.com/cohline-series-2633-w...u=RH25HPWRAPPED It in Tyngsboro right off route 3 - order ahead for will-call pick up they hate drop ins or have it shipped |
| porschetub |
Jul 8 2025, 03:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,204 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
1970 914-6, all original All Teeners Yea I get it, we teeners are special - very special. And, considering this little fact so are the prices of the most benign little part. The webbing for the oil tank hoses on my 914-6 are a bit frayed and I went to source some and - YOW!! If anyone has a reasonable source or is hording hose, let me know, spending 600+ on oil hoses......well, just seems a bit TOO SPECIAL. (IMG:style_emoticons/default/dry.gif) Read the quotes at the various sites carefully, they lull you in with 58.00 and then when you get ready to order the price is PER FOOT! (IMG:style_emoticons/default/mad.gif) Are you talking 22mm ID oil line hose ? braided oil line hose from $18/ft on Elephant Racing ,thats were I got mine many years ago and it has gone up as I bought mine @ 12/ft , might pay to check them . I presume you intend to replace hose only and that's fine , new ferule's are @ Stoddards @ under 4 bucks each if you use your old fittings again ,thats where I got mine. Cheers. |
| ctc911ctc |
Jul 8 2025, 06:12 PM
And This Teeners is more like it! (IMG:style_emoticons/default/biggrin.gif)
Will check these sellers out! (IMG:style_emoticons/default/beerchug.gif) Thank you, Respectfully, CTC911CTC 1970 914-6, all original All Teeners Yea I get it, we teeners are special - very special. And, considering this little fact so are the prices of the most benign little part. The webbing for the oil tank hoses on my 914-6 are a bit frayed and I went to source some and - YOW!! If anyone has a reasonable source or is hording hose, let me know, spending 600+ on oil hoses......well, just seems a bit TOO SPECIAL. (IMG:style_emoticons/default/dry.gif) Read the quotes at the various sites carefully, they lull you in with 58.00 and then when you get ready to order the price is PER FOOT! (IMG:style_emoticons/default/mad.gif) Are you talking 22mm ID oil line hose ? braided oil line hose from $18/ft on Elephant Racing ,thats were I got mine many years ago and it has gone up as I bought mine @ 12/ft , might pay to check them . I presume you intend to replace hose only and that's fine , new ferule's are @ Stoddards @ under 4 bucks each if you use your old fittings again ,thats where I got mine. Cheers. |
| porschetub |
Jul 8 2025, 10:10 PM
Elephant woven hoses are 2 grades one is a plain hose and the other is wire reinforced but both have the same pressure and temp rating ,happy to help cheers.
| BillJ |
Jul 8 2025, 10:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,357 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
I may have some spares if that helps. Will need to find them
| rgalla9146 |
Jul 9 2025, 06:05 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,033 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
If you are replacing the hose on original fittings you need 2' for the two between
tank and the cooler. The one in front of the engine (smaller diameter) is less than one foot. You have all the fittings ? Lucky dog, keep it original. (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) |
| ctc911ctc |
Jul 9 2025, 03:50 PM
Here are my hoses
I was/am most concerned with the two top ones ![]() |
| 930cabman |
Jul 9 2025, 06:19 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,888 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
AFAIK Pegasus has steel braided hose and fittings
| fixer34 |
Jul 9 2025, 06:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Little bit of confusion here. Those are 'breather lines', not 'oil lines'.
There is little/no pressure in them. Not really sure why they are cloth braided on the outside, doesn't need the strength. Pretty much any kind of oil resistant hose will work, although I understand the desire for originality. Keep looking, yea $50+ per foot is ludicrous unless you are going for concours. Your old ones don't look that bad |
| mepstein |
Jul 9 2025, 06:40 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,016 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Little bit of confusion here. Those are 'breather lines', not 'oil lines'. There is little/no pressure in them. Not really sure why they are cloth braided on the outside, doesn't need the strength. Pretty much any kind of oil resistant hose will work, although I understand the desire for originality. Keep looking, yea $50+ per foot is ludicrous unless you are going for concours. Your old ones don't look that bad (IMG:style_emoticons/default/agree.gif) we get those lines for something like $5 a foot from SSF. They are cloth braided but not under pressure. |
| mepstein |
Jul 9 2025, 06:57 PM
I just checked. Continental cloth braided hose. part # N2037115, 19mm, $15 a meter + ship (whatever shipping cost me). Let me know if that works for you and I'll order it up.
| rgalla9146 |
Jul 9 2025, 06:59 PM
Little bit of confusion here. Those are 'breather lines', not 'oil lines'. There is little/no pressure in them. Not really sure why they are cloth braided on the outside, doesn't need the strength. Pretty much any kind of oil resistant hose will work, although I understand the desire for originality. Keep looking, yea $50+ per foot is ludicrous unless you are going for concours. Your old ones don't look that bad (IMG:style_emoticons/default/agree.gif) we get those lines for something like $5 a foot from SSF. They are cloth braided but not under pressure. Hey Mark ... who is SSF ? |
| mepstein |
Jul 9 2025, 07:01 PM
I have some in my stash. If you want me to send you a sample, PM me your address and I'll drop it in the mail. That way you can be sure before you commit. (IMG:style_emoticons/default/beerchug.gif)
| mepstein |
Jul 9 2025, 07:02 PM
Little bit of confusion here. Those are 'breather lines', not 'oil lines'. There is little/no pressure in them. Not really sure why they are cloth braided on the outside, doesn't need the strength. Pretty much any kind of oil resistant hose will work, although I understand the desire for originality. Keep looking, yea $50+ per foot is ludicrous unless you are going for concours. Your old ones don't look that bad (IMG:style_emoticons/default/agree.gif) we get those lines for something like $5 a foot from SSF. They are cloth braided but not under pressure. Hey Mark ... who is SSF ? The largest distributor of Porsche parts in the country. |
| porschetub |
Jul 9 2025, 07:24 PM
Here are my hoses I was/am most concerned with the two top ones ![]() Had you been more exact and said breather hose, we would have been on the right track...nevermind, Stoddard have 24mm breather/vent braided hose so check them out . Cheers. Slow to reply and well covered by the earlier response's ok. |
| BillJ |
Jul 10 2025, 11:50 AM
Glad you got solved! These are the ones I have that are available
| live free & drive |
Jul 10 2025, 08:06 PM
It is probably below from Belmetric, I would assume it was originally a Cohline product:
https://belmetric.com/cohline-series-2122-c...se/?sku=RH14X20 Not sure if it is 14mm ID x 20mm OD that you need or the next size up. |
Lo-Fi Version | Time is now: 24th November 2026 - 06:10 PM |
