 Forum Rules Classified Rules!
> FS Porsche 914 race car, 1974 Porsche 914 2.1L for sale $15900 Free Shipping
jackspru
post Jul 11 2025, 08:40 PM
Vehicle Overview:
This is a highly modified 1974 Porsche 914-4, transformed into a race-ready machine. The extensive work has been performed by reputable specialists, focusing on performance, safety, and reliability for track use. It has a vintage VARA logbook, indicating its history in racing events. The car is exceptionally lightweight at 1880 lbs (without fuel). Car is located in Dallas, Texas but will be shipped free to continental USA.
Engine (Built by Dwayne Anderson Racing Enterprises):
Type: 2.1 Liter (originally 2.0L)
Compression: 10.5:1
Pistons: 96mm forged JE pistons
Cylinders: Steel
Camshaft: Webcam 134c full race camshaft
Valves: 38mm & 48mm
Heads: Ported & polished
Valve Springs: High-pressure dual
Valve Guides: New silicon bronze
Carburetion: Weber 44mm IDF carbs with aluminum K&N air filters
Crankshaft: Counterweighted, knife-edged
Rods: Rebuilt, shot-peened
Flywheel: Super lightweight (7 lbs)
Clutch: Stage 3 pressure plate, lightweight 6 puck clutch
Oil System:
Accusump oil accumulator
Deep oil sump (holds 2 extra quarts)
Front & rear oil coolers (will keeps engine cool even in desert heat)
All braided steel oil lines with AN fittings
Transmission (Renovated by Justin Desmone):
Gears: Completely rebuilt with M-S-X gears
Components: All new bearings, gaskets, and synchros
Shifter: Tangerine Racing shifting rod
Brakes:
Front: "M" caliper vented 911 front brakes with dedicated cooling ducts
Rear: Larger rear calipers
Pads: Porterfield R-4 pads all around
Control: Brake bias adjuster
Master Cylinder: 19mm
Suspension and Chassis:
Shocks/Struts: Bilstein
Front Camber: Camber plates for ample adjustment
Tie Rods: Turbo tie rods
Torsion Bars: 23mm front
Rear Springs: 225 lbs
Sway Bars: 19mm front, 16mm rear
Wheel Conversion: Converted to 5-lug wheels with Porsche studs
Chassis: Stripped down, full roll cage (FIA legal)
Fuel System: FIA legal 12-gallon ATL fuel cell
Body: Flared rear fenders to accommodate wider tires (8" wheels with 225/50 or 245/45 rear tires)
Interior & Safety:
Roll Cage: (FIA legal)
Seat: Kirkey racing seat
Dash: New dash with new wiring
Belts: New belts
Steering Wheel: Momo steering wheel
Shift Knob: Momo shift knob
Fire System: New fire system with nozzles throughout the car
Wheels & Tires:
Tires: New Toyo R888s
Wheels: Lightweight racing wheels with magnesium center pieces
- Lo-Fi Version Time is now: 12th July 2025 - 10:59 AM
