sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 956 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Stoddard has pre bent brake line kit in galvanized or “ green”.
If you want “correct” assuming you stay with galvanized. Comments? |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,385 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
We did pre-bent, green lines in my car. No problems and fitment was very good. Sourced through PMB. (IMG:style_emoticons/default/beerchug.gif)
Jack Standz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 513 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() ![]() |
If you go with stainless steel(availablefrom PMB), understand that these lines are harder.
Put a set on a few weeks ago and had to really tighten them before they stopped leaking. |
flyer86d |
Member ![]() ![]() Group: Members Posts: 469 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States ![]() |
I make my own. When I owned my shop I’m Vermont, replacing rusty brake lines was a weekly job. You can buy new fittings with the material of your for tubing. You just need a tubing bender, a tubing cutter, and bubble flair tool for Porsches and other european cars.
Charlie |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,305 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
If you go with stainless steel(availablefrom PMB), understand that these lines are harder. Put a set on a few weeks ago and had to really tighten them before they stopped leaking. Unless you plan on racing or Very heavy braking, the standard steel lines are just fine |
dtmehall |
Member ![]() ![]() Group: Members Posts: 132 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest ![]() |
Aren't the flexible lines the 'weak link' anyway?
Jack Standz |
If you go with stainless steel(availablefrom PMB), understand that these lines are harder. Put a set on a few weeks ago and had to really tighten them before they stopped leaking. Unless you plan on racing or Very heavy braking, the standard steel lines are just fine The standard tin coated steel lines work fine. But, the stainless ones do not corrode over time (especially with hygroscopic brake fluids), look cool and are less expensive than the green ones. |
sbsix |
only the lead dog enjoys a change in scenery... ![]() ![]() Group: Members Posts: 457 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California ![]() ![]() |
Years ago I bought several front brake lines from Stoddard that were green coated. I learned that they were indeed NOS green coated.
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,444 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
If you go with stainless steel(availablefrom PMB), understand that these lines are harder. Put a set on a few weeks ago and had to really tighten them before they stopped leaking. Same here. And it took REALLY torquing the flare nut wrench, as advised by PMB. Even then I had a couple of junctions that still weeped. PMB sent me some special sealant for those. |
sixaddict |
Thanks all
Lo-Fi Version | Time is now: 15th July 2025 - 08:29 AM |
