Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,500 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
Can you measure the distance of the pedal face to firewall. Want to know how close they are to stock position.
And what master cylinders you are using. I'm tall with the seat all the way back, and don't think I'll like loosing too much leg room. Thanks |
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,615 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
You'll want to run their 76 series master cylinders as they allow both the fluid in and out via fittings on the top of the cylinders vs the pressure lines out the front. This allows the pedals to be installed as far forward as is possible, which is all but in the same place as the factory pedals. Watch starting at 4:25 and you'll see how I worked it out. Hope this helps.
https://www.youtube.com/watch?v=Re86R1IwXOk |
Lo-Fi Version | Time is now: 31st July 2025 - 10:20 AM |
