StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,176 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
Finally replacing my lower frunk latch. Bought a nice replated single spring unit from a fellow member, only to find once I removed the original one that it has TWO springs, as @bdstone914 had mentioned.
Is there a functional difference between the two? The one spring version has a tiny annoying set screw (replating has filled the head slot!) while the two spring version has a nice big cheesehead screw. @bdstone914 did you find the nice replated two spring unit you though you had? ![]() ![]() |
StarBear |
Moved the smaller second spring and cheesehead screw over to the replated unit.
StarBear |
Duplicate
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,048 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Finally replacing my lower frunk latch. Bought a nice replated single spring unit from a fellow member, only to find once I removed the original one that it has TWO springs, as @bdstone914 had mentioned. Is there a functional difference between the two? The one spring version has a tiny annoying set screw (replating has filled the head slot!) while the two spring version has a nice big cheesehead screw. @bdstone914 did you find the nice replated two spring unit you though you had? ![]() ![]() Yes I found one. The two spring seem to return better. |
StarBear |
@bdstone914
Thanks! Will install the replated unit with scavenged spring and screw (see pic) today. Will let you know. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 19th July 2025 - 01:59 AM |
