| Dlee6205 |
Jul 19 2025, 06:55 AM
Member ![]() ![]() Group: Members Posts: 88 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
I've had these on the shelf for some time... finally time to release some. I'm selling two options here.
Option 1: This kit includes the powder coated compressor mount, pulley adapter, pulley, and hardware. The mount is designed for a Sanden 507 style compressor and you must have the smog style fan housing with the extra mounting provisions. This does NOT include a compressor or v-belt. This option is $250 plus shipping. I have 3 of these available. Option 2: This is just the pulley adapter, pulley, and hardware. This is a good option if you plan to use a different compressor and/or want to make your own mount. The cost of this option is $125 plus shipping. I have 3 of these available. If you are interested, please send me a message with which option you're interested in and an email to which I can send an invoice. ![]() ![]() ![]() |
| 914Sixer |
Jul 19 2025, 05:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,436 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Will the later Sanden 508 work with mount?
| 914rrr |
Jul 20 2025, 07:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,035 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
I don't have an immediate need for these, but thanks for your time and effort in putting these together!
| Dlee6205 |
Jul 23 2025, 05:10 PM
| Dlee6205 |
Jul 23 2025, 05:12 PM
| friethmiller |
Jul 24 2025, 08:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,194 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
Will the later Sanden 508 work with mount? If I'm remembering correctly, the 508 is about 1/2" longer and that's reflected in the mounting ears too. The front of the compressor would likely bolt up fine, the rear might need a spacer. I think mine is a 508. Doug, you provided the mount kit. I just welded it together. In your latest rendition, I see improvements with the mount attachment points on the fan housing. Great improvement, IMO. ![]() |
| Mr.Vman |
Jul 26 2025, 05:41 PM
Newbie ![]() Group: Members Posts: 28 Joined: 1-October 24 From: Sierra Vista, AZ. Member No.: 28,388 Region Association: Southwest Region |
Please count me in on your compressor drive kit for grooved belt. Difficult to navigate side, not sure what is going on. Please PM me and we can go from there. Thank you, Steve
| Jack Standz |
Jul 27 2025, 11:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 736 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
@Dlee6205
Asking here because it may be helpful to others. We used to have a bus case with those extra mounts, but sadly it is gone. What years VW/411/914, etc. cases had these mounts? And do you need the entire case or does it bolt up to a standard cooling housing? |
| Dlee6205 |
Jul 27 2025, 07:08 PM
@Dlee6205 Asking here because it may be helpful to others. We used to have a bus case with those extra mounts, but sadly it is gone. What years VW/411/914, etc. cases had these mounts? And do you need the entire case or does it bolt up to a standard cooling housing? Honestly, I only know 914s (IMG:style_emoticons/default/laugh.gif) This would have been on 76 914s that required SMOG and you would need both halves of the cooling shroud/assembly. |
Lo-Fi Version | Time is now: 18th March 2026 - 11:58 PM |
