> Removed Tow Bar - Now What?
Osnabruck914
post Jul 29 2025, 12:37 PM
My car came with this ridiculous and heavy (22 lbs) tow bar assembly mounted under the nose. I put up with it for over ten years, hitting innumerable curbs, driveway dips, and parking space stops and today I finally removed it.
My question now is, how do you safely pull a 914 from the front onto the bed of a flatbed truck (which were the only instances I ever used the tow bar for)? Where should a tow guy attach his chains/straps underneath safely, where nothing will break, to winch the car forward onto the truck?
Thank you.
Osnabruck914
Replies(1 - 12)
DRPHIL914
post Jul 29 2025, 02:53 PM
Dr. Phil
get a tow bar from Rich 914werke
http://www.914werke.com/
post Jul 29 2025, 04:55 PM
914-6 GT in waiting
Grab an axle strap at harbor freight, amazon, etc and throw it in the trunk. Loop it over the reinforcement strut on the a-arm and the tow driver can hook his chain to it.
Krieger
post Jul 29 2025, 06:18 PM
That looks like a lot more than 22lbs
Literati914
post Jul 29 2025, 06:31 PM
QUOTE(mepstein @ Jul 29 2025, 05:55 PM) *
Another great idea!! Hadn't thought of this either! (IMG:style_emoticons/default/beer.gif)
post Jul 29 2025, 06:43 PM
914-6 GT in waiting
QUOTE(Literati914 @ Jul 29 2025, 08:31 PM) *
I've done it dozens of times to pull a car onto my trailer with the winch.
Osnabruck914
post Jul 29 2025, 07:12 PM
Thanks Mepstein. That solves my problem!
Osnabruck914
bkrantz
post Jul 29 2025, 07:50 PM
If you are really paranoid, get some of these.
https://tangerineracing.com/shop/ols/produc...front-tie-downs
porschetub
post Jul 29 2025, 11:17 PM
QUOTE(bkrantz @ Jul 30 2025, 01:50 PM) *
Is the tow hook underneath rubbish ,don't know cause never been towed...
Cheers.
post Jul 30 2025, 06:41 AM
914-6 GT in waiting
QUOTE(porschetub @ Jul 30 2025, 01:17 AM) *
Cheers.
Usually a rollback will have a bunch of extras to make it work but the large hook on the end of the cable won't always fit the tow hook. There isn't a lot of clearance between the loop and the floor pan. It also can scratch the paint. The $10 strap solves the issue 99% of the time.
Sometimes deep spoilers are an issue.
DRPHIL914
post Jul 30 2025, 07:21 AM
Dr. Phil
QUOTE(mepstein @ Jul 30 2025, 08:41 AM) *
Cheers.
Thats a great idea, use the strap for that center tow loop just to pull up onto the trailer with the come-along winch, i did that before i put the tow bar for flat towing on,
i guess my earlier comment was because i was thinking about him doing this on a regular basis but if he's not going to flat tow and just pulling onto a trailer once and awhile definitely doesn't need the flat tow bar.
Osnabruck914
post Jul 30 2025, 03:50 PM
mepstein,
Got myself today a couple of the Harbor Freight axle straps you recommended. Now just to be clear, is the best attachment point on the a-arm(s) where I circled in the attached pic?
Osnabruck914
post Jul 30 2025, 04:13 PM
914-6 GT in waiting
QUOTE(Osnabruck914 @ Jul 30 2025, 05:50 PM) *
mepstein,
Osnabruck914
Yes, that portion of the a-arm is more than strong enough to pull your car up the incline of a rollback.
- Lo-Fi Version Time is now: 1st August 2025 - 08:36 AM
