| partwerks |
Aug 5 2025, 06:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,642 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Car had been sitting for a couple years, but last I recall, the fresh air blower fan worked, but now, the light comes on, but fan is not working?
Any thoughts, ideas, or suggestions? |
| jim_hoyland |
Aug 5 2025, 07:04 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,104 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
The light is not wired directly to the fan. The light ground on the slider contacts on the vent control; power can come from any 12v wire.
So, just because the vent control light comes on its not directly related to the fan itself. |
| Jgilliam914 |
Aug 5 2025, 07:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,375 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
Cleaning the contacts on the sliders worked for me getting it to work.
| partwerks |
Aug 5 2025, 08:02 PM
| dtmehall |
Aug 5 2025, 08:06 PM
Member ![]() ![]() Group: Members Posts: 326 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
not to rain on your parade....it could be the motor. that happened to me in the same way
| jim_hoyland |
Aug 5 2025, 08:44 PM
Here’s the fans inputs. Red is 12v, the other three are ground that you activate at the vent control. Do you have 12 V ?
| partwerks |
Aug 5 2025, 09:24 PM
| jim_hoyland |
Aug 6 2025, 05:34 AM
IIRC , the plug attaches to the bottom of the blower assembly
| RiqueMar |
Aug 6 2025, 01:31 PM
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,264 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California
I know it probably sounds silly, though check the fuse as well. Recently, in high-heat driving through the Central CA Valley a fuse melted and I had a similar result.
| jim_hoyland |
Aug 6 2025, 04:00 PM
Check the fuse # 8; it powers the cig lighter, fresh air blower, and windshield wiper motor, plus air blower indicator lamp. One of the Red/White wires goes to the fan.
| partwerks |
Aug 7 2025, 07:12 PM
Tried a different relay also, but didn't work, so I put the old one back in place. Anyway, it gudgingly started to work, but I can only get it to work on 2nd speed. No high, or low speed??
| Dave_Darling |
Aug 7 2025, 11:16 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,356 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Sounds like the contacts in the sliders.
--DD |
| jim_hoyland |
Aug 8 2025, 05:49 PM
Definitely a slider issue; see if you can reach in and push down on a slider that’s not working. Not easy getting in there; I removed the radio and could get a better shot at it.
Unfortunately you can’t pull the vent control out unless the Bowden cables are released at the valves Also, verify the three wires are attached to the three contact strips; I had one come off and thought the fan was going south…. Attached thumbnail(s) |
| RBR53 |
Aug 8 2025, 07:53 PM
Newbie ![]() Group: Members Posts: 19 Joined: 1-August 25 From: Youngstown, OH Member No.: 28,902 Region Association: None |
I just did this earlier today. Remove the ash tray and it’s easy. I used a wire brush and contact cleaner. Went from totally inop to all three fan speeds and the indicator light working. Before and after shown.
Dan Attached thumbnail(s) |
| Steve |
Aug 8 2025, 10:46 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,059 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Doesn’t help that it’s below the ash tray. When I bought my car back in 1986 it was covered in ashes.
| jim_hoyland |
Aug 9 2025, 08:58 AM
Check these connections. Mine had a tendency to slip off.
| DRPHIL914 |
Aug 11 2025, 07:46 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,955 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
Here’s the fans inputs. Red is 12v, the other three are ground that you activate at the vent control. Do you have 12 V ? i have seen these wires put back in by a previous owner incorrectly so it was only working on the middle setting, and would not work low or high, but if left in that position with pop the fuse too. sliders needed to be cleaned but the problem was mainly the wiring being crossed so make sure those are in the right place as well as cleaning your contacts etc. - new fan motors and assembly are available if you are taking it out i would strongly suggest you get a new motor and fan you will have the box apart to put in new seals anyway. My fan works better than new now. Phil |
| jim_hoyland |
Aug 11 2025, 12:55 PM
@Dr. Phil
Who sells the replacement fan motors. ? |
Lo-Fi Version | Time is now: 27th July 2026 - 06:32 AM |
