> Carpet around the E Brake, Add your pics
trojanhorsepower
post Aug 11 2025, 03:06 PM
How did you handle this area of the carpet?
Replies(1 - 14)
iankarr
post Aug 11 2025, 04:57 PM
You just need to pull and stretch, and have a really strong glue like DAP Weldwood Landau Top and Trim.
trojanhorsepower
post Aug 11 2025, 05:06 PM
Thanks Ian,
I was just hoping for some pictures of the area so I can see how other people handle the area around Handle and cables.
Thanks
Peter
wonkipop
post Aug 11 2025, 05:16 PM
@trojanhorsepower
the factory handled this whole sill piece differently in the carpet itself.
it had a kind of clear plastic backing and this was added to the carpet stock backing.
then it appeared to have been pressed in a heat form to the shape of the lhs sill.
the passenger side was just normal carpet stock.
a couple of other interior carpet pieces were formed the same way.
namely the one behind the passenger seat which was formed to go over electrical connections and relays for interlock and also the central tunnel piece.
of course impossible to replicate. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/sad.gif)
you have to do it as @iankarr says
i started at the hand brake recess and then worked away in both directions.
mine is of course rhd so i was never going to be able to buy any factory NOS stock no matter what. i got a good result. but the trick is start glueing at the recess itself. get it nailed down and then work away from it.
the tunnel represents similar challenges to get the shape to conform just right, but not as difficult as sill. the factory never glued that down on the tunnel - it conformed to the shape naturally with the moulding layer on the backing. i found if i only glued along the flat edges where it sits on the cabin floor i got a pretty good result. also easy to get up again if needing to do tunnel work, cables access etc.
trojanhorsepower
post Aug 11 2025, 05:27 PM
Thanks, I guess Ill just do my best.
bkrantz
post Aug 11 2025, 07:35 PM
One thing to think about: if you have stock type carpet, with the obvious rows, you can keep the rows straight on top of the sill, or along the base of the side. Whichever you choose, the rows will curve on the other.
I chose the top, and probably added work, but I like the results.
bkrantz
post Aug 11 2025, 07:36 PM
View of the side.
trojanhorsepower
post Aug 12 2025, 09:53 AM
Thanks bkrantz.
This is what I wound up with.
It's OK, but....
Root_Werks
post Aug 12 2025, 02:07 PM
Village Idiot
I need to do something with my carpet around the ebrake as well. I've heard a heat gun will help mold the carpet into the e-brake detent?
bkrantz
post Aug 12 2025, 07:00 PM
QUOTE(Root_Werks @ Aug 12 2025, 02:07 PM) *
I used heat, two doses of contact cement, and clamping with a block of wood cut to fit the recess.
burton73
post Aug 14 2025, 01:51 PM
Senior member, and old dude
The custom carpet treatment on my factory 6
Best Bob B
trojanhorsepower
post Aug 14 2025, 02:12 PM
I wound up spraying water on it, then heating the back with a heat gun. Then two passes with the glue and carefully work it into place. It came out OK, but I didn't get glue in one spot so there is a bubble.
friethmiller
post Aug 14 2025, 02:26 PM
Yeah, this area is tricky. I must admit that I struggled with this as well. I just didn't like the results on my first attempt so I pulled the carpet back up, added more Wellwood, and focused on keeping everything straight and pressing things in firmly.
Scott760
post Aug 14 2025, 02:43 PM
QUOTE(friethmiller @ Aug 14 2025, 01:26 PM) *
I am looking for a black carpet. Wondering where you got your's. Love the look! Thanks
friethmiller
post Aug 15 2025, 09:41 AM
QUOTE(Scott760 @ Aug 14 2025, 03:43 PM) *
914 rubber, actually.
- Lo-Fi Version Time is now: 16th August 2025 - 12:33 AM
