pedrok |
Newbie ![]() Group: Members Posts: 32 Joined: 1-January 08 From: Chula Vista, CA Member No.: 8,525 Region Association: None ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Show the whole crank.
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,121 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Back when, we brought our dowel pin count to 8. But that was a type 1. This is like someone added dowel pins to a type 4 crank.
pedrok |
Jack Standz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 537 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() ![]() |
We have a very lightened "racing" flywheel with 5 dowels like this one. So, yes, some type iv flywheels and crankshafts did get this treatment.
But, no crankshaft to go with it. Thought it might be good for a project at the time, but it's had way too much material removed for any practical use. At least it's not likely going into anything we have planned. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,915 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I've not seen that before ,has been "wedge mated " like they do with T1 cranks ??.
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,456 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
Jack Standz |
Back when, we brought our dowel pin count to 8. But that was a type 1. This is like someone added dowel pins to a type 4 crank. Very rare, the flywheel doesn't have the holes Thanks Would not call it "very rare". But, it's not normally used for stock or stockish motors. European Motor Works (and others) will perform this on your crank for $65. https://www.europeanmotorworks.com/vw/crank...ft-service.html |
pedrok |
Thank you guys!
Lo-Fi Version | Time is now: 22nd August 2025 - 08:05 PM |
