> 14 pin connector wire ends, Looking to source wire ends that fit the 14 pin connector.
tjgalvin
post Aug 25 2025, 11:49 AM
I want to terminate anew several wires on my 914 relay board. The wires have an end that connects 90 degrees to the wire and fits snugly into a hole on the connector. I can't find a source for just the wire ends.
Thanks.
Replies(1 - 8)
JeffBowlsby
post Aug 25 2025, 11:58 AM
One source:
https://www.djetparts.com/product-page/smal...nnector?lang=en
Wes's part number 99965237612 for a 3mm female solder-on barrel terminal is correct for the 12-pin and 14-pin connector housings.
914Wes
post Aug 25 2025, 02:58 PM
I believe it is 99965237612 after doing more research. The source Jeff listed is a third of the Porsche price.
Steve
post Aug 25 2025, 03:27 PM
It might be cheaper and easier to just buy the whole thing. https://www.pelicanparts.com/More_Info/9116...sHLJIzx26mn06QZ
930cabman
post Aug 25 2025, 05:01 PM
possibly salvage a couple from a "dead" connector?
Dave_Darling
post Aug 26 2025, 11:33 PM
914 Idiot
It looks like the Pelican one has bullet connectors, possibly? The photo is not that clear.
If you're creative, I think you could use bullet connectors. Drill a hole in the side near the top and that might work.
--DD
Steve
post Aug 27 2025, 08:45 AM
QUOTE(Dave_Darling @ Aug 26 2025, 10:33 PM) *
--DD
That’s the part number i used to eliminate the relay box and build my six wiring harness. When I converted from a 2.7 to a 3.2 and then a 3.6, I just moved the pins around to match the new motor.
IronHillRestorations
post Aug 27 2025, 10:17 AM
I. I. R. C.
Female pins are 99965237612, and available from any Porsche dealer
dr914@autoatlanta.com
post Aug 27 2025, 11:32 AM
we have hundreds as we repair harnesses in our 914 restoration shop all of the time. Of course they need to be soldered on!!!!
QUOTE(tjgalvin @ Aug 25 2025, 10:49 AM) *
Thanks.
- Lo-Fi Version Time is now: 28th August 2025 - 01:41 AM
