Marcel Aircooled |
Newbie ![]() Group: Members Posts: 48 Joined: 28-April 24 From: The Netherlands Member No.: 28,087 Region Association: Europe ![]() |
When checking my spark plugs I found a loose piece of hard plastic inbetween the no. 2 cilinder and the engine tin. It turns out to be one of the alternator inspection covers. I have no idea how it got there and unfortunately it is just too big to fit through the spark plug hole in the engine tin so I cannot get it out of there. I found the plastic piece a year ago and only just recently found out it is one of the inspection covers and it does not seem to do any harm where it is now but it just bugs me knowing it is there. Does anyone have any suggestions on how to get it out from under the engine tin without removing the engine? Would it be easy to remove the engine tin only where the plastic piece is located? Or any suggestions how to break or bend the plastic piece?
Here's a picture (sorry for the poor quality) of the piece seen through the spark plug hole ![]() This is an example picture of the part I am talking about ![]() |
infraredcalvin |
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,669 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California ![]() ![]() |
Can you actually grab ut? I’d use one of those lost bolt grabbers to pull it up to the SP hole and cut/break it with some cutters and fish out the little pieces.
Marcel Aircooled |
Thanks Pat. I can grab it with a pair of pliers but then there is no space left to cut or break it easily and I am a bit afraid to damage the engine tin. Also not sure what happens if I do break it and there are pieces left behind. Might give it a try though unless someone comes up with a brilliant suggestion (IMG:style_emoticons/default/wink.gif)
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,857 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
It’s the plug for the access holes for the alternator adjustment.
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,775 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
That's a tough one, probably too large to pull through the spark plug hole? Maybe not too wide, but too long?
Jack Standz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 538 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() ![]() |
You can undo the fasteners for the tin and grab hold of it with a pair of long nosed pliers or a surgical clamp. Did this with a spark plug and/or socket last year sometime (can't remember why we couldn't get it back throug the hole in the tin). And, yes we used a magnetic thing. You don't have to completely remove the tin, just enough to pull it up enough to reach in with extra long pliers or a clamp. Not difficult.
Or try holding it up to the spark plug hole with some long nosed pliers and taking it out in pieces with some side cutters. But, it's really not necessary. When we got around to rebuilding a motor that was removed from a 914 about 15 years earlier, it had a spark plug that was laying on/behind #3 cylinder. Who knows how long it had been in there. You can just leave it. |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,354 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
It's plastic and light. You could proably get away with just putting some gorrilla tape or some high-temp aluminum tape (that stuff is super sticky) folded over on itself to be doubesided and use it on the end of something skinny to get get in there and snag it.
Marcel Aircooled |
It’s the plug for the access holes for the alternator adjustment. |
Marcel Aircooled |
Marcel Aircooled |
You can undo the fasteners for the tin and grab hold of it with a pair of long nosed pliers or a surgical clamp. Did this with a spark plug and/or socket last year sometime (can't remember why we couldn't get it back throug the hole in the tin). And, yes we used a magnetic thing. You don't have to completely remove the tin, just enough to pull it up enough to reach in with extra long pliers or a clamp. Not difficult. Or try holding it up to the spark plug hole with some long nosed pliers and taking it out in pieces with some side cutters. But, it's really not necessary. When we got around to rebuilding a motor that was removed from a 914 about 15 years earlier, it had a spark plug that was laying on/behind #3 cylinder. Who knows how long it had been in there. You can just leave it. OK, this I can try, thanks Jack! I know it is not necessary and the piece must have been there probably since the rebuild by Auto Atlanta in 2017 or short after but it just bugs me a lot knowing that it is there and that I cannot get it out (IMG:style_emoticons/default/biggrin.gif) |
Marcel Aircooled |
It's plastic and light. You could proably get away with just putting some gorrilla tape or some high-temp aluminum tape (that stuff is super sticky) folded over on itself to be doubesided and use it on the end of something skinny to get get in there and snag it. Thanks for the tip James. That might be a good idea to get it close to the SP hole only not sure what to use to break it as it is too big to fit through the hole. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,242 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The worst thing it is doing is very slightly affecting the air flow to part of one of your cylinders. Probably not enough to notice in the long term. It might make a little noise as well, but unlikely you would hear it over all the rest of the noise the engine makes.
Removing the engine tin with the engine in the car is possible, but a huge pain. There's a lot of stuff you have to get out of the way first--basically everything on top of the engine on that side. And even then, space in the engine bay is tight to move that large piece of tin around. I don't think it's worth bothering with until you have to pull the motor for some other reason. --DD |
Lo-Fi Version | Time is now: 29th August 2025 - 07:22 PM |
