> 914World Classifieds Rules
> WTB: Left front hood hinge assembly, Needed due to DAPO
BillC
post Aug 28 2025, 06:09 PM
So I'm replacing my front hood gasket and treating the rust in the channel, when I discovered that the DAPO has struck again. (IMG:style_emoticons/default/headbang.gif)
At some point, the driver's side (left) front hood hinge bolt must have broken off, and it was "repaired" poorly. I need a replacement.
Does anyone have a good, stock front left hood hinge assembly for sale? Preferably in Alaska Blue Metallic, but I'll take any color as long as it's in good shape. I'll even take a matching pair, if necessary.
At a minimum, I need the hinge bolt (part #914-512-191-10) and the left-side hood hinge bracket (part #914-511-037-10), which is the part that bolts to the body (the part that bolts to the hood appears to be fine).
Please let me know what you have.
Thanks!
Replies(1 - 4)
bdstone914
post Aug 28 2025, 09:24 PM
bdstone914
QUOTE(BillC @ Aug 28 2025, 05:09 PM) *
Thanks!
I saw one in the shop but have to check which side it fits.
I have a parts car but it will be at least a couple weeks before I start pulling parts from it. I should have all the hardware
BillC
post Aug 29 2025, 12:17 PM
QUOTE(bdstone914 @ Aug 28 2025, 11:24 PM) *
Thanks!
Unfortunately, I can't really wait a couple of weeks. I'm signed up for an event in a couple of weeks and need to get the car back together before then.
Anyone else have the parts?
post Aug 29 2025, 01:36 PM
914-6 GT in waiting
I’m pretty sure I have some. One side had a bolt break off in the threads but if I remember correctly, that’s probably something you can handle. Free if I have them. Might be a day or two before I check the stash.
I should have the hinge bolt as well.
BillC
post Aug 29 2025, 02:43 PM
QUOTE(mepstein @ Aug 29 2025, 03:36 PM) *
Yup, no problem drilling out a broken bolt and restoring the threads. If I have to, I could fix this one, but it would have to be welded up first -- the DAPO drilled it out off-center, and then jammed an SAE screw into it. Which also explains why the hood never lined up quite right.
- Lo-Fi Version Time is now: 29th August 2025 - 07:24 PM
