> Accelerator Cable Jam Nut, 914-6 Special?
DennisV
post Sep 8 2025, 09:37 AM
What is special about this jam nut for the accelerator cable? 914-423-287-00
The PDF parts catalog describes it as "hexagon nut", and only lists it under the 914-6 models and it doesn't appear to be used anywhere else on the car. I've of course searched the interwebs. It is NLA and I can't find any photos of it. I assume they gave it a unique part number for a reason... (IMG:style_emoticons/default/confused24.gif)
Replies(1 - 7)
Cfletch
post Sep 8 2025, 10:28 AM
I doubt its anything special, I think its just used to lock the sheath to the bracket on the transmission, basically a sandwich. I don't have the stock bracket, but one from Rich Johnson and its the same as the other one on the other side of the bracket. Curious to see if there's actually a need for a separate part number.
ctc911ctc
post Sep 8 2025, 07:10 PM
914-6, 1970 - all stock and original
I am getting ready to put the engine back in and I recalled a component that I thought was interesting - here it is:
essentially a wide nut with 1/2 of the nut HEX and the other half is round.
DennisV
post Sep 9 2025, 07:55 AM
QUOTE(ctc911ctc @ Sep 8 2025, 06:10 PM) *
Good memory! Thanks for sharing.
I think that is called a shoulder nut? If you have an opportunity, can you share the dims on the nut?
* Size across the flats (ATF)?
* Overall length
* I assume the inside is M6?
ctc911ctc
post Sep 10 2025, 08:24 PM
Here is the information about this 'fancy' nut, I seem to remember seeing these before, perhaps this is a standard part?
DennisV
post Sep 11 2025, 06:56 AM
QUOTE(ctc911ctc @ Sep 10 2025, 07:24 PM) *
That is super helpful!
I assume it is 10mm ATF? Can you tell if it is a lock nut or there is anything else "special" about it? I am perplexed, and getting a bit nuts about this nut. (IMG:style_emoticons/default/head_hurts_kr.gif)
I will add this to the parts vault if you don't mind me reposting your images.
ctc911ctc
post Sep 11 2025, 11:12 AM
NOT a lock nut, my files are your files.
QUOTE(DennisV @ Sep 11 2025, 06:56 AM) *
DennisV
post Sep 12 2025, 09:35 AM
I did a lot of searching for Porsche, VW, and generic parts. Couldn't find anything identical. This Tall Fixture Nut from BelMetric is the closest approximation I could find. It appears to be 1mm taller than your original. I guess one could turn down the hex on half of it to get the collar.
- Lo-Fi Version Time is now: 12th September 2025 - 05:59 PM
