ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,209 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,115 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Can you show where it is in the engine compartment? I can look on my 6.
ctc911ctc |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,316 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I'm pretty sure that's an original part, i have seen them on quite a few 914s.
(IMG:style_emoticons/default/idea.gif) |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,950 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) -6 no return line..block off plug..
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,909 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
With the /6 being carburated, I would assume there is no return line and therefore one of the hole would be capped with this plug? (IMG:style_emoticons/default/confused24.gif)
From the PET diagram, single line and your part (#19). Its description is: Stopper used on 1.8. but also referenced as being used on /6 on AA website. ![]() ![]() |
wonkipop |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,036 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
With the /6 being carburated, I would assume there is no return line and therefore one of the hole would be capped with this plug? (IMG:style_emoticons/default/confused24.gif) From the PET diagram, single line and your part (#19). Its description is: Stopper used on 1.8. but also referenced as being used on /6 on AA website. ![]() ![]() yes thats the stopper for a 1.8V (V being the twin carb euro 1.8). which makes sense that its maybe same part that came from earlier 6. also carb. though PET does not list it as 6 part anywhere i can find. but would not be first time PET is not entirely complete. |
DennisV |
Senior Member ![]() ![]() ![]() Group: Members Posts: 715 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California ![]() ![]() |
On the right side of the car engine compartment - 914-6 There are two oval holes for the 914-4 FI, one is plugged with this when it is a 914-6 engine. Is this an original part? Is this located down by the base of the battery tray? Our car has one plug and one grommet with a hole in the middle. Attached thumbnail(s) ![]() |
sbsix |
only the lead dog enjoys a change in scenery... ![]() ![]() Group: Members Posts: 461 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California ![]() ![]() |
Parts for the three spots on the engine tin on a 914-6
sbsix |
sbsix |
parts are NLA but last time I checked AA had replacements. These would be a great idea for 914 Rubber to make.
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,207 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
yes for six only plugged the four cylinder fuel line return hole in the engine shelf. We had them made for awhile but our molder Jerry, died
On the right side of the car engine compartment - 914-6 There are two oval holes for the 914-4 FI, one is plugged with this when it is a 914-6 engine. Is this an original part? |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,805 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Lo-Fi Version | Time is now: 12th September 2025 - 05:59 PM |
