rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,104 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
rfinegan |
These heads were purchase here and included: welding of the ports and chambers seats and guides as well as around spark plug holed and one cert to a stopped plug hole
Prep included: Blast with 120 mesh aluminum oxide to combustion, chamber and valves Clean with acetone I did not gas as the oven was not use (air cured) Tape 1 coat of Cerakote piston coating to combustion chambers, valves, back of exhaust valves and exhaust ports Air cure 5 days |
Jack Standz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 540 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() ![]() |
Excellent.
A couple questions if you don't mind. Why not bake the heads after the Ceracoat? How did you mask the sealing surfaces to keep the coating from messing up the seal? Thanks |
rfinegan |
Yeah they offer oven cure and catalyst hardeners, this one is 5 day air cure. the end result should be the same?
The area on the head was blue taped, the vertical edged and the folded over then wider tape to cover the bottom of the head. I just use 4 of the head gaskets you get in rebuild kits and set one on each head. The added tape help them tight. A little clean up with acetone. I did the same with the exhaust ports and back of exhaust valve and use a old brass seal the same way as above t okeep the are free of coating Excellent. A couple questions if you don't mind. Why not bake the heads after the Ceracoat? How did you mask the sealing surfaces to keep the coating from messing up the seal? Thanks |
rfinegan |
...you can see the exhaust seal in the pic to keep the surface free of coating
rfinegan |
Oh, the ear plugs seal off holes very well that you do not want coating (or blasting)....see pic and spark plug holes
mate914 |
Matt ![]() ![]() ![]() Group: Members Posts: 893 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States ![]() ![]() |
Looks great. Can't wait to try..
Matt |
rfinegan |
rfinegan |
rfinegan |
Lo-Fi Version | Time is now: 14th September 2025 - 11:51 PM |
