> Front end shimmy at speed
VaccaRabite
post Sep 13 2025, 02:13 PM
En Garde!
When I’m on the freeway I get a vibration through the steering wheel if I’m going over 70.
On surface roads everything is smooth sailing.
It’s probably a wheel that threw off its weight, but I can’t check that till Monday.
Bearing are new. Rotors are new.
What’s the checklist?
Replies(1 - 4)
rjames
post Sep 13 2025, 02:57 PM
I'm made of metal
A lost wheel weight is a solid culprit.
How old are the tires? Maybe tread separation? Do you have a spare you could use to swap your wheels out one at time to rule them out?
Grab the wheels and check for play to ensure it's not a loose or bad bearing (or worn spindle), too.
emerygt350
post Sep 13 2025, 03:15 PM
QUOTE(VaccaRabite @ Sep 13 2025, 02:13 PM) *
I just went through that too except I had just put turbo tie rods on. Luckily I decided to have the weights checked, and sure enough, it had thrown a weight. I really need to learn to photograph the wheel...
Cairo94507
post Sep 13 2025, 04:44 PM
Michael
When I had my wheels balanced, I used black racers tape to cover the weights since the backs of the wheels are black. Never lost a weight yet. Also, on my car, deep sixes with 195x65x15 Michelin tires, I have found they are sensitive to tire pressure. If one of my tires get's 2 pounds low, I can feel a slight vibration. Air tires and smooth as glass again.
BTW, I run my tires at 28F and 31R. I have no idea if that is good or bad, but my cars rides great. (IMG:style_emoticons/default/beerchug.gif)
emerygt350
post Sep 13 2025, 05:05 PM
QUOTE(Cairo94507 @ Sep 13 2025, 04:44 PM) *
I was putting duct tape over mine. Seemed to work. When I was doing the high performance driving school at the Glen, the weights laying on the ground were knee deep in the green group paddock....
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: T.Rick6
- Lo-Fi Version Time is now: 13th September 2025 - 06:49 PM
