> Webcam 73 valve clearance, Does the Webcam change the exhaust valve adjustment
timofly
post Sep 22 2025, 03:15 PM
My 2.0 (actually probably about 2.2 with oversized cylinders) car has had a Webcam 73 in it since a complete overhaul in 2010. I have used the usual recommendation of .006 intake and .008 exhaust for 15 years. I recently read something (and I can't recall where) that said that with the Webcam, the exhaust should be at .006. I know the 1.7 and 1.8 engines called for that, and maybe the source was referring to those engines, but I am curious. It's time for another adjustment. I've always assumed that a bit more clearance might mean the engine will be noisier, but it's less likely to be a cause for deep regrets that setting them too tight. Anybody ever heard this suggestion for .006 on the 2.0 cars?
Replies(1 - 4)
Millerwelds
post Sep 22 2025, 04:01 PM
Pleepleus
I don't recall where I saw it either but it raised the same question for me. Also a 2.0 that I have used .006 and .008 for the last 10 years with a Webcam 73 in it. Would love to know the answer. Thanks for asking the question! (IMG:style_emoticons/default/popcorn[1].gif)
porschetub
post Sep 22 2025, 04:12 PM
QUOTE(timofly @ Sep 23 2025, 09:15 AM) *
My understanding is that .008 was used when VW used sodium filled valve's , the cam used has no bearing on this and is recommended because sodium exhaust valves are a thing of the past .
You will be fine with .006 ,cheers.
Jack Standz
post Sep 22 2025, 04:58 PM
Here's what Webcam says:
https://webcamshafts.com/pages_vehicles/aut...691_000544.html
.006 intake and .006 exhaust, but if you're running aftermarket pushrods (i.e. chromoly versus aluminum), make sure to look at what the manufacturer says.
cgnj
post Sep 22 2025, 05:25 PM
QUOTE(porschetub @ Sep 22 2025, 03:12 PM) *
(IMG:style_emoticons/default/agree.gif) 2.0 used Na filled valve to improve heat transfer. It's no longer a thing unless you still have Na filled valves. I guess the disposal problems outweighed the thermal improvement.
- Lo-Fi Version Time is now: 22nd September 2025 - 11:26 PM
