> 2.0L head temp sensor access, Sensor removal
SWH
post Oct 11 2025, 10:15 PM
I have problem with idle fluctuation and want to replace head temp sensor on 2.0L. Can sensor be removed without removing right side intake? Looks like tight fit and wanted others opinion.
Replies(1 - 6)
wonkipop
post Oct 11 2025, 11:15 PM
Krieger
post Oct 12 2025, 09:20 AM
Certainly worth sacrificing a no name deep socket.
rjames
post Oct 12 2025, 10:57 AM
I'm made of metal
A too lean mixture can cause a hunting idle. If you have the adjustment knob on your ECU and haven’t tried adjusting already, try turning it clockwise a click or three.
SWH
post Oct 12 2025, 05:17 PM
Thank you for the answers to my reques. Head temp sensor has been ordered. Should be here by Tuesday. Tried to find the right size socket. Not sure if it’s 17 mm. Can you tell me what size I should be looking at?
sdthomas
post Oct 12 2025, 09:56 PM
13 mm deep socket. Just removed mine today.
This thread might help.
QUOTE(SWH @ Oct 12 2025, 03:17 PM) *
brant
post Oct 13 2025, 06:19 AM
Another way to make a tool is to grind one corner of a 3 inch cheap extension
Pass the wire through the 13mm socket and through the ground corner of the extension
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: SWH
- Lo-Fi Version Time is now: 13th October 2025 - 07:24 PM
