dlindzey |
repeat offender ![]() Group: Members Posts: 43 Joined: 8-April 14 From: texas Member No.: 17,226 Region Association: Southwest Region ![]() |
Are the clearances for intake and exhaust valves the same for 1.7, 1.8 and 2.0 engines?
My engine has been modified with a kit to 1.97-big piston kit, would that influence recommended valve clearances? |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,301 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Are the clearances for intake and exhaust valves the same for 1.7, 1.8 and 2.0 engines? My engine has been modified with a kit to 1.97-big piston kit, would that influence recommended valve clearances? If I remember correctly the 1.8 is different and the kit won't affect the valve adjustment. Things that would are different valves and the addition of hydraulic lifters. If you know what the heads are from that will likely tell you the required clearance. |
Jack Standz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() ![]() |
If you are running chromoly pushrods versus aluminum pushrods after the kit install, then there will be changes to the valve lash/clearances.
Lo-Fi Version | Time is now: 13th October 2025 - 07:24 PM |
