Aayala |
Newbie ![]() Group: Members Posts: 3 Joined: 7-July 25 From: Austin Tx Member No.: 28,874 Region Association: South East States ![]() |
Hello! First post here… I was wondering if anyone could verify if this looks like some sort of repair done by someone on the cylinder heads of my 1975 Porsche 914 1.8L engine? I am starting the process of tearing the engine down because it was seized. I got pretty far as to remove all of the cylinders including the one that was seized. Had to soak it in some mystery oil for over a day and finally took it apart. The cylinder heads and cylinders to my surprise on one side looked pretty new from the inside, on the other side however not so much. Cylinder #1 was the one that was seized and the rest looked in good condition. I have the receipts from 1990s that the engine was rebuilt by a Porsche mechanic shop in Austin along with all of the part numbers to confirm. What did catch me by surprise was that upon closer inspection of the cylinder 1 head, the exterior ring looked different than all others. Can someone please let me know if this is some repair job done and this is what caused the failure of the engine most likely? Seems like a coincidence that this was the only cylinder with an issue and the head was also different than all others. Would love any feedback anyone could give! I’m probably replacing the head itself but if that is not the cause then I would see how they look after cleaning. Thank you again in advance!
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,097 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
(IMG:style_emoticons/default/welcome.png) Looks like casting flaw. Well not really a flaw just part of the casting. A repair would have been done in the combustion chamber where a crack would have formed or a repair of damage from a dropped seat.
Artfrombama |
Artfrombama ![]() ![]() Group: Members Posts: 382 Joined: 21-January 24 From: North Alabama Member No.: 27,870 Region Association: South East States ![]() ![]() |
I see a casting flaw that is well outside of the combustion chamber but the sealing ring is distorted and likely leaking compression.
I've heard where using these rings is optional. Perhaps other more knowledgeable builders will chime in. |
rick 918-S |
Start by getting them cleaned and crack checked. There are a lot expensive ways to do it so check around.
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,328 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
That looks like a casting sprue or vent location. A sprue is where the metal is injected into the mold, and a vent is where gasses escape from the mold. Some metal may escape from the vent also. The grinding marks are probably from removing flash.
Lo-Fi Version | Time is now: 16th October 2025 - 12:16 AM |
