> 914World Classifieds Rules
> WTB front Fuel Line Grommet, Who makes them.?
gandalf_025
post Oct 20 2025, 07:41 AM
I’m looking for one of these fuel line grommets for the front, under the gas tank.
Any ideas where to find one..???
And does anyone know if they are the same for a 4 and 6.??
Replies(1 - 11)
Montreal914
post Oct 20 2025, 09:47 AM
What year? Depends where your charcoal canister is.
gandalf_025
post Oct 20 2025, 10:35 AM
No canister… it is a 70. 6
GaroldShaffer
post Oct 20 2025, 10:54 AM
You bought another 914?
I have this one.
sbsix
post Oct 20 2025, 11:01 AM
only the lead dog enjoys a change in scenery...
My 1970 914-6 uses two individual front bulkhead grommets for the fuel lines under the gas tank. The double hole grommet is too large to fit.
914werke
post Oct 20 2025, 11:38 AM
very early cars (70 ?) used a couple of simple line grommets but did switch to the 2 hole grommet pictured through 74?
Last a updated 3 hole vers was installed in late 75-76 cars
The 2 hole vers presumably has asymmetric sized holes to fit the metal tips on the lines.
The late version has 2 symmetrical line holes + the 3rd is a small one for the charcoal evap system that was now the tunnel.
gandalf_025
post Oct 20 2025, 01:18 PM
Well, I decided to go out and check the car and apparently
I had a senior moment or 2 because, yes there are indeed
2 holes, not the single 1 I thought was there.
So the next question would be…
Are They the same as the rear ones..??.
GaroldShaffer
post Oct 20 2025, 09:37 PM
These are the ones you need for under the tank. Pulled from a early 70 chassis. Not dry rotted.
Message me if interested
KSCarrera
post Oct 21 2025, 01:18 AM
Region Association: England
They are the same part number as VW Bug speedometer cable grommets that go under the front fender. They are readily available from most VW parts suppliers, and I believe from 914 Rubber.
bdstone914
post Oct 21 2025, 05:25 AM
bdstone914
QUOTE(KSCarrera @ Oct 21 2025, 12:18 AM) *
They are available new from Porsche for about $10 each and Uro parts.
Probably available from VW too.
KSCarrera
post Oct 21 2025, 05:57 AM
QUOTE(bdstone914 @ Oct 21 2025, 12:25 PM) *
From VW shops they're about $3.00 each, or less.
914Wes
post Oct 21 2025, 07:53 AM
https://www2.cip1.com/c16-111-861/ $2.34 each
- Lo-Fi Version Time is now: 23rd October 2025 - 07:14 PM
