| dlindzey |
Oct 22 2025, 09:54 AM
repeat offender ![]() ![]() Group: Members Posts: 51 Joined: 8-April 14 From: texas Member No.: 17,226 Region Association: Southwest Region |
I can't even find a shop willing to change my oil so I am going to have to crawl around on the floor for a while. I have all the parts and a creeper but get confused on where you can put a floor jack and where you should put a jack stand as seems like same point is best for both the jack and the stands.
I have located the 4 donuts at the corners of the cab/chasis juncture, they seem ok. I am tempted to just get two floor jacks and jack up the rear at the donuts and call it a day. Is it dangerous to use jacks for support rather than putting a jack stand under there somewhere? Ramps won't work as exhaust tip hits the ramp. How do most of you solve this issue? |
| mepstein |
Oct 22 2025, 10:04 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
You absolutely need jack stands or at the very least, something that will catch the car if the jack fails. I used to jack up the car and then put the ramps under the wheels once the car was high enough in the air. Turn the ramp backwards if it’s a better fit. You are just using it as a stand, not an incline device.
Jack failure is a thing. My wife would tell me about it when she worked surgical shock trauma. My local mechanic used to change my oil. You don’t need a Porsche shop to do it. |
| emerygt350 |
Oct 22 2025, 10:19 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,508 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I wouldn't let a shop change my oil. Too much stuff to look over while while down there and the dreaded oil screen bolt. Assuming a 4 cylinder.
I back onto ramps when I do mine. I also do the slide the ramp under the tire bit for other work. I will put a jack stand under the engine cross member when poking around under there since I do use the donuts for the jack. |
| Superhawk996 |
Oct 22 2025, 11:22 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Never . . . Ever . . . Get under a jacked up car without jack stands.
| emerygt350 |
Oct 22 2025, 11:30 AM
| rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,447 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
I had issues with the tailpipe hitting the ramps I have so I built some ramps out of stacked 1x10 boards. They don't get the car as high off the ground as the ramps would, but high enough to change the oil. If I need the car up higher I'll use the jack stands.
When I jack up the car I use a short piece of 2x4 under the longs. That leaves the donut clear to get the jackstand under it. |
| dlindzey |
Oct 22 2025, 12:09 PM
thanks for all the feedback
when putting jackstands under do you jack the car up 12" and put a stand in place and then go the other side or do you go back and forth inch at a time or----any technique to minimize potential damage? |
| gereed75 |
Oct 22 2025, 12:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
The cylindrical inner portion of the trailing arms where they bolt into the inner suspension mount is a good place for the jack stands IMHO.
I usually jack one side up the whole way, insert the jack stand, then do the other side. Then check that the first jack stand has not tilted. Re- jack the first side and readjust the jack stand to ensure it is squarely parked on the floor. I also block under the wheels just in case. |
| Superhawk996 |
Oct 22 2025, 12:25 PM
thanks for all the feedback when putting jackstands under do you jack the car up 12" and put a stand in place and then go the other side or do you go back and forth inch at a time or----any technique to minimize potential damage? Ya. It all sort of depends on your jack and the stands you have. But as a general statement - lifting one side too high all at once can side load the jack stands which isn’t a good idea. Keep an eye on the opposite stand what lifting to make sure it isn’t side loading and/or getting tippy. |
| Jack Standz |
Oct 22 2025, 01:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 743 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
I can't even find a shop willing to change my oil so I am going to have to crawl around on the floor for a while. I have all the parts and a creeper but get confused on where you can put a floor jack and where you should put a jack stand as seems like same point is best for both the jack and the stands. I have located the 4 donuts at the corners of the cab/chasis juncture, they seem ok. I am tempted to just get two floor jacks and jack up the rear at the donuts and call it a day. Is it dangerous to use jacks for support rather than putting a jack stand under there somewhere? Ramps won't work as exhaust tip hits the ramp. How do most of you solve this issue? Those "donuts" are not designed to jack up your 914. They will bend/deform. Use a jack plate inserted into the jack point Porsche designed for jacking up your 914. Here is a diagram showing where you can place stands. Although it shows the "donuts" in the diagram, those are not good/safe locations for jacking up your 914. You decide where its safe and less prone to damage your 914. When we don't jack up the 914 using the jacking point, we use a 4x4 (maybe it's 6x6?) piece of hardwood that goes almost the entire width of the car and is placed under the firewall when jacking up the rear and under the area behind the front cross member when jacking up the front. Since we use a 4 post lift and two tall stands, it is very quick. One stand on each side of the 4x4 and then lower the lift and lock the safety catches and we're ready to work. Best wishes for a safe oil change. One final comment. It is very very dangerous to have an incompetent shop/mechanic change the oil on a 914. If the bolt that fastens the strainer cover is tightened with too much torque, you can end up with "type iv syndrome ". This is where the internal part of your engine case breaks and pretty much destroys the engine. At a minimum it's a very expensive repair. Attached image(s)
| Osnabruck914 |
Oct 22 2025, 05:36 PM
Member ![]() ![]() Group: Members Posts: 208 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States |
Quote from Jack Standz - "Those "donuts" are not designed to jack up your 914. They will bend/deform."
Then what pray, are they for? Almost every car I've ever owned has had similar donuts or sometimes squares for use as jacking points. I've been jacking 914s for decades using those donuts with never a problem. When I go to a garage (which is rarely) they lift the car using those donuts. A rust bucket of course is another story. Porsche must have had a reason to put them there. Osnabruck914 |
| emerygt350 |
Oct 22 2025, 07:42 PM
Quote from Jack Standz - "Those "donuts" are not designed to jack up your 914. They will bend/deform." Then what pray, are they for? Almost every car I've ever owned has had similar donuts or sometimes squares for use as jacking points. I've been jacking 914s for decades using those donuts with never a problem. When I go to a garage (which is rarely) they lift the car using those donuts. A rust bucket of course is another story. Porsche must have had a reason to put them there. Osnabruck914 I am with you on this but apparently the donuts were for attachment during construction and were all joined to a single jig so no one donut ever held the weight alone. I can see that, but just try and stop me from using them as jack points... |
| mepstein |
Oct 22 2025, 08:06 PM
Quote from Jack Standz - "Those "donuts" are not designed to jack up your 914. They will bend/deform." Then what pray, are they for? Almost every car I've ever owned has had similar donuts or sometimes squares for use as jacking points. I've been jacking 914s for decades using those donuts with never a problem. When I go to a garage (which is rarely) they lift the car using those donuts. A rust bucket of course is another story. Porsche must have had a reason to put them there. Osnabruck914 I am with you on this but apparently the donuts were for attachment during construction and were all joined to a single jig so no one donut ever held the weight alone. I can see that, but just try and stop me from using them as jack points... The donuts fit the pins on the car carrier that moved the cars down the line during construction. It’s not very heavy duty metal and they tend to bend easily. There are stronger points on the car that work better for raising the car. |
| Jack Standz |
Oct 23 2025, 12:16 AM
Quote from Jack Standz - "Those "donuts" are not designed to jack up your 914. They will bend/deform." Then what pray, are they for? Almost every car I've ever owned has had similar donuts or sometimes squares for use as jacking points. I've been jacking 914s for decades using those donuts with never a problem. When I go to a garage (which is rarely) they lift the car using those donuts. A rust bucket of course is another story. Porsche must have had a reason to put them there. Osnabruck914 Not the first time this has been discussed: http://www.914world.com/bbs2/lofiversion/i...hp?t344274.html Now, if you had some kind of a jig to raise the car by all 4 "donuts" at the same time like the factory assembly line, maybe it's OK. But, if you jack the car up by just one, they can and do bend. With enough experience with 914s, you must have seen it before, right? Either way, using the jacking point with a jack or a jacking plate is how Porsche envisioned owners to jack up their 914s. Attached image(s)
| wonkipop |
Oct 23 2025, 01:26 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
as a uni student i used to park my old type 3 variant up with one wheel on top of the kerb, slide under and drain the oil that way.
probably not the go in the modern eco ruled world hey? (IMG:style_emoticons/default/biggrin.gif) and it was a bit higher than a 914. and i did not have to crawl as far. i'd go jack stands. lucky for me i have access to a hoist. and since we are debating donuts. i lift it on the hoist on the donuts. but its all four all sharing the load simultaneously. have not bent a donut yet. however one donut at a time might make me think twice. esp those back ones under the engine bay. |
| 914043 |
Oct 23 2025, 09:41 PM
Member ![]() ![]() Group: Members Posts: 103 Joined: 2-April 19 From: California Member No.: 23,007 Region Association: Central California
Is using the engine with a protective soft piece of wood or hearty rubber pad between the floor jack and the engine case at the drain point not acceptable. Always thought it a little risky but the only way I've found to get a six high enough to be able to pull the engine out from under the car.
| GBX0073 |
Oct 23 2025, 10:48 PM
Member ![]() ![]() Group: Members Posts: 185 Joined: 21-December 20 From: Illinois Member No.: 25,007 Region Association: Upper MidWest
Low profile (Daytona harbor freight) jack Placed in the center under the engine support bar Using a 2X4 the length of engine mount bar
I jack up the car High Enough to place Quality jack stands under the Donuts Lower the car onto the Donuts Keep the jack still under the car under the support and pivot the jack a little so I can still roll under with the creeper After chasing a leak you get pretty proficient jacking the car up not F1 pit stop fast but fast |
| L-Jet914 |
Oct 23 2025, 11:36 PM
Member ![]() ![]() Group: Members Posts: 389 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I used to use the old school metal drive on ramps. Then years later, I finally invested in a QuickJack set.
| rgalla9146 |
Oct 24 2025, 06:38 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Is using the engine with a protective soft piece of wood or hearty rubber pad between the floor jack and the engine case at the drain point not acceptable. Always thought it a little risky but the only way I've found to get a six high enough to be able to pull the engine out from under the car. This is going to cause some flak. I put the floor jack under the rear of the transmission avoiding the speedo cable and the gearshift linkage by using a 6" 2x4 against the trans. I then support the car with jack stands I've done this on 4 and 6 cyl cars for years and it never caused any damage. Never lift a car with jack further forward under the engine. |
| sixnotfour |
Oct 24 2025, 07:59 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
(IMG:style_emoticons/default/beerchug.gif) Me too..since 1978 (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/popcorn[1].gif)
Lo-Fi Version | Time is now: 2nd April 2026 - 11:56 AM |
