| Literati914 |
Oct 22 2025, 10:53 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,113 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Are there any common reasons that the turn signals would not be self cancelling like they are supposed to? - like, could the wheel have been mounted up side down or something ? The crest on the pad is oriented correctly but that may be possible either way. I did not necessarily check where the "cancelling nub" was located on the back of the wheel when I installed it. Or, since I had the wheel taken apart at one point (was looking at doing a quick release but didn't follow thru) could I have gotten something misaligned when it was put back together?
I'd take the wheel off and investigate but I'm not gonna have the car for a couple days and was hoping to have an idea before getting it back. |
| Literati914 |
Oct 22 2025, 07:16 PM
Anyone got any ideas?
| Chad911sc |
Oct 22 2025, 07:26 PM
Member ![]() ![]() Group: Members Posts: 198 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
I’ll be watching….mine doesn’t either |
| dtmehall |
Oct 22 2025, 07:49 PM
Member ![]() ![]() Group: Members Posts: 186 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
years ago, i broke the canceling nub, and ending up replacing the switch
| 914Sixer |
Oct 23 2025, 06:28 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,301 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Make sure these pieces are in place in the switch. Plastic pins break and spring falls out.
Attached thumbnail(s) |
| ctc911ctc |
Oct 23 2025, 06:52 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,262 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
I have fixed this a few times in my '74, the 70 seems to have no trouble.
With the 74 I replaced the entire turn signal assembly for another problem and then this occurred as a result. seems that the entire operation is dependent on a variety of systems to be lubed and also aligned........lovable analog car....... specifically the depth of the turn assembly when sitting in the hub is critical, in my 74 the NEW assembly was not quite built so that it sat firmly in the hub (these assemblies are made for a variety of cars, so they may be perfect in a beetle, or Ghia, etc.) I may go back in there....may not..... Also, there is a requirement for the wheel to turn more that 180 degrees for the auto-off to work, in NE most of the intersections are NOT 90 degrees......... hhhmmmm....after this I am energized to get back in there and fix this! |
| jim_hoyland |
Oct 23 2025, 07:42 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,920 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
| DRPHIL914 |
Oct 23 2025, 07:46 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,863 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States
Make sure these pieces are in place in the switch. Plastic pins break and spring falls out. I bought a pair of replacement pieces for broken plastic ones. They’re brass. Jim., please pass along the source for this part. |
| ctc911ctc |
Oct 23 2025, 12:29 PM
Make sure these pieces are in place in the switch. Plastic pins break and spring falls out. I bought a pair of replacement pieces for broken plastic ones. They’re brass. Jim., please pass along the source for this part. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
| jim_hoyland |
Oct 23 2025, 01:35 PM
I have a pair of these but not sure how to get them mounted without breaking something else
| jim_hoyland |
Oct 23 2025, 02:01 PM
Sorry for the messed up link: Here’s how to search for the info:
Key search words: *turn* *signal* And put 914Sixer in the name box Search under 365 days in all forums. |
| jim_hoyland |
Oct 23 2025, 02:26 PM
eBay: See 914sixers post ….
| 914Sixer |
Oct 23 2025, 04:24 PM
Here you go
| jim_hoyland |
Oct 23 2025, 05:47 PM
That’s it; my question is how do you get them in ????
Lo-Fi Version | Time is now: 23rd October 2025 - 07:15 PM |
