> Rear Trunk Oddball Features?
DennisV
post Oct 22 2025, 07:49 PM
I ran across three things in our rear trunk that seem unusual. Perhaps they are DAPO mods. Can anyone confirm?
1. What appears to be a ground strap
2. A clip at the bottom of the trunk lid
3. Small rubber grommet from the firewall.
Thank you.
Replies(1 - 10)
Montreal914
post Oct 22 2025, 08:01 PM
Doesn’t look stock.
fixer34
post Oct 22 2025, 08:21 PM
None of those are on mine.
nivekdodge
post Oct 22 2025, 08:24 PM
Could 1. be a ground to eliminate noise on a cb radio? and 3 be the cable passthru
Kevin
dtmehall
post Oct 22 2025, 08:25 PM
not on my 73
DennisV
post Oct 23 2025, 05:03 AM
QUOTE(nivekdodge @ Oct 22 2025, 07:24 PM) *
Kevin
3 does look like a hose or cable grommet. Do you know what would pass thru there?
rgalla9146
post Oct 23 2025, 06:06 AM
All goofy DAPO mods
fixer34
post Oct 23 2025, 07:55 AM
QUOTE(nivekdodge @ Oct 22 2025, 09:24 PM) *
Kevin
None of those are 'stock', but this could be a likely explanation.
#1 provides a better ground connection/plane for the back trunk lid.
#2 clips the antenna cable when the lid is opened
#3 is the antenna cable passthru from the engine compartment. Cable likely run thru the tunnel into the cockpit.
Antenna probably a clamp on, or even magnetic base that attached to rear lid. Pretty common 30+ years ago,
Unless you are going for full factory stock/concours, I would leave them alone. Shows that PO put some effort into it.
NARP74
post Oct 23 2025, 09:57 AM
And you need to put the witches hat back on.
BillJ
post Oct 23 2025, 10:07 AM
I think he wants full on total original based on everything he has said and done thus far.
Root_Werks
post Oct 23 2025, 10:44 AM
Village Idiot
QUOTE(rgalla9146 @ Oct 23 2025, 05:06 AM) *
All goofy DAPO mods
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: tomeric914
- Lo-Fi Version Time is now: 23rd October 2025 - 07:12 PM
