| chmillman |
Oct 25 2025, 08:34 AM
Member ![]() ![]() Group: Members Posts: 180 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
So, while I had the steering wheel off to fix the ignition switch, I thought it would be the perfect time to fix the other problem I had - the high beam indicator light wasn't working.
Previously I was able to pull the gauge panel partially out with the steering wheel still on, in doing so I was able to replace the existing dash lighting tungsten bulbs with LED's - but I could never get the bulb for the brights indicator out - it was stuck in place and impossible to remove in that position. So finally with the steering wheel off, I disconnected the various wires and pulled the whole tach gauge out. Then, on the bench, I was finally able to gradually work the brights indicator lamp holder out of the socket in the gauge. Mine is a '74, but it actually has a '73 or earlier tach, with the individual left/right turn signal arrows at the top (which I much prefer over the later version) and the brights indicator at the bottom. I pulled the existing bulb out and tested it... and it worked. I was like huh? Why am I not seeing it light up in the gauge? So then I held the gauge up to the light and looked into the socket hole to see if I could see anything. Nothing. Then I tried holding the soocket side against a really strong light and looked from the front - and then I dimly saw some blue light... So I surmise that over 50 years, the blue plastic has simply aged and gotten darker, to the point where it's almost opaque. Nothing I can do about that short of having the gauge rebuilt - which it doesn't need, the tach works perfectly, as do the turn signal indicators. I put in the brightest front-facing BA7 LED's I have been able to find - the right one in the image below. I have one of these already in the green parking lights indicator on the speedo and it's almost too bright. Now I can kinda sorta see a faint blue glow if I'm driving the car in the dead of night with the high beams on. During the day though, it's still invisible. So if you think yours is not working, it might be the same as mine. |
| Montreal914 |
Oct 25 2025, 09:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,951 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Early 74 had silver button gauges which would make the tach like the 73 with separate blinkers. Maybe this is your case and your speedometer was replaced? (IMG:style_emoticons/default/confused24.gif)
| Ron914 |
Oct 25 2025, 10:08 AM
Member ![]() ![]() Group: Members Posts: 436 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
Thanks for posting this . I too have your problem of the high beam bulb not working . I will have to check the lens when I replace all my lamps with led's of course I have read enough about this job I know not to replace the generator lamp with a led .Never would of suspected the lens .
| Ron914 |
Oct 25 2025, 10:14 AM
Early 74 had silver button gauges which would make the tach like the 73 with separate blinkers. Maybe this is your case and your speedometer was replaced? (IMG:style_emoticons/default/confused24.gif) I just replaced my rear tail lights with new led's from Spokeworks and have to change my flasher relay because I have the single turn indicator lamp . I thought about as you mentioned replacing the tach with the older style but then I have a new problem as the gauge needle dots won't match , mine are all black and the older gauges are silver . |
| Spoke |
Oct 25 2025, 10:41 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,262 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I thought about as you mentioned replacing the tach with the older style but then I have a new problem as the gauge needle dots won't match , mine are all black and the older gauges are silver . Ron, I did the early tach into a '74 so I could have individual turnsignal indicators. I popped off the chrome dot and black center needles with a small fork and put the black center needle on the early tach. Here's my thread on changing the tach bodies on my '74 914. Spoke's '74 914 ![]() |
| Rob-O |
Oct 25 2025, 11:09 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,285 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
The trick I used was the use colored tabs for hanging file folders. I did this for the ‘low fuel’ light as well. If I remember correctly I had to double or triple the thickness on the red. Looked great with just the little red plastic piece in there but once the light turned on the material was so thin the light looked almost pink. Just added two or three pieces to make it thicker (they were taped on) to achieve the right shade when the light was on.
Attached thumbnail(s) |
| chmillman |
Oct 25 2025, 02:21 PM
Early 74 had silver button gauges which would make the tach like the 73 with separate blinkers. Maybe this is your case and your speedometer was replaced? (IMG:style_emoticons/default/confused24.gif) Well, mine is an “early” ‘74 in that it came off the Karmann assembly line November 1st 1973. So it might still have had some “leftover” 1973 parts as delivered originally - no idea. The main gauges are definitely all “silver dot” centers. The most interesting is that it also has a ‘73 motor number and ‘73 EFI with the Bosch 037 MPS and control box and the 270 ohm resistor. Again, no idea if that was original or not when delivered, it’s also possible they could have changed the motor when they restored the car. The chassis number is definitely 1974. As far as changing out the old blue lens goes, I’m not sure I want to mess around with opening up what is an otherwise good working tach… |
| wonkipop |
Oct 25 2025, 02:37 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,171 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
Early 74 had silver button gauges which would make the tach like the 73 with separate blinkers. Maybe this is your case and your speedometer was replaced? (IMG:style_emoticons/default/confused24.gif) Well, mine is an “early” ‘74 in that it came off the Karmann assembly line November 1st 1973. So it might still have had some “leftover” 1973 parts as delivered originally - no idea. The most interesting is that it also has a ‘73 motor number and ‘73 EFI with the Bosch 037 MPS and control box and the 270 ohm resistor. Again, no idea if that was original or not when delivered, it’s also possible they could have changed the motor when they restored the car. The chassis number is definitely 1974. As far as changing out the old blue lens goes, I’m not sure I want to mess around with opening up what is an otherwise good working tach… the "early" 74 2.0s are for all intents and purposes pretty much 73 2.0s in terms of parts apart from some obvious necessary changes for regs. notably rear over-riders on bumper. your car if it is nov 1 73 is pretty much the last of these early 74 2.0s. right at the end of october they started building the 1.8s which were delayed due to the new L jetronic EFI. (they may have built euro 1.8s before october but not the USA cars). they pretty much pump 1.8s out for nov, dec 73 and jan 74 and if any 2.0s were built were few and far between (possibly only to satisfy special order customers). thats when the cars begin to get truly updated with all the new 74 changes in detail. after feb 74 the 2.0s go back into serious production volumes again and all the LEs are built during that time. thats why there is a difference referred to by some as early 2.0s and late 2.0s in 74. i have on file an example of a very early 1.8 dating from oct 30 73 and its got the black dials. its right about then that they stop using the silver dot dials and switch to black. all the updates seemed to get held back until the moment they start producing the 1.8s. however its bound to be pretty smudgy right around then as the parts get used up. (IMG:style_emoticons/default/beerchug.gif) |
| chmillman |
Oct 26 2025, 02:02 AM
the "early" 74 2.0s are for all intents and purposes pretty much 73 2.0s in terms of parts apart from some obvious necessary changes for regs. notably rear over-riders on bumper. your car if it is nov 1 73 is pretty much the last of these early 74 2.0s. right at the end of october they started building the 1.8s which were delayed due to the new L jetronic EFI. (they may have built euro 1.8s before october but not the USA cars). they pretty much pump 1.8s out for nov, dec 73 and jan 74 and if any 2.0s were built were few and far between (possibly only to satisfy special order customers). thats when the cars begin to get truly updated with all the new 74 changes in detail. after feb 74 the 2.0s go back into serious production volumes again and all the LEs are built during that time. thats why there is a difference referred to by some as early 2.0s and late 2.0s in 74. i have on file an example of a very early 1.8 dating from oct 30 73 and its got the black dials. its right about then that they stop using the silver dot dials and switch to black. all the updates seemed to get held back until the moment they start producing the 1.8s. however its bound to be pretty smudgy right around then as the parts get used up. (IMG:style_emoticons/default/beerchug.gif) Cool, thanks for that info! Explains a lot about this car, which despite having a ‘74 chassis number, has a lot of ‘73 in it. So it probably is more or less as original. Previously I tried to get the history of the car from Porsche Switzerland here - mainly to see if the motor is the original one - but they said they couldn’t find the car in their system. |
| wonkipop |
Oct 26 2025, 02:21 AM
the "early" 74 2.0s are for all intents and purposes pretty much 73 2.0s in terms of parts apart from some obvious necessary changes for regs. notably rear over-riders on bumper. your car if it is nov 1 73 is pretty much the last of these early 74 2.0s. right at the end of october they started building the 1.8s which were delayed due to the new L jetronic EFI. (they may have built euro 1.8s before october but not the USA cars). they pretty much pump 1.8s out for nov, dec 73 and jan 74 and if any 2.0s were built were few and far between (possibly only to satisfy special order customers). thats when the cars begin to get truly updated with all the new 74 changes in detail. after feb 74 the 2.0s go back into serious production volumes again and all the LEs are built during that time. thats why there is a difference referred to by some as early 2.0s and late 2.0s in 74. i have on file an example of a very early 1.8 dating from oct 30 73 and its got the black dials. its right about then that they stop using the silver dot dials and switch to black. all the updates seemed to get held back until the moment they start producing the 1.8s. however its bound to be pretty smudgy right around then as the parts get used up. (IMG:style_emoticons/default/beerchug.gif) Cool, thanks for that info! Explains a lot about this car, which despite having a ‘74 chassis number, has a lot of ‘73 in it. So it probably is more or less as original. Previously I tried to get the history of the car from Porsche Switzerland here - mainly to see if the motor is the original one - but they said they couldn’t find the car in their system. yeah, i am sure it is pretty original. there is more i could tell you but i would not worry too much. its bound to be pretty well right. ok - right. since you are in switzerland, why not try out my theory. which is a VW birth certificate should be possible for your 914. after all, it was a VW porsche in europe. they were built by karmann under VW management. porsche were simply (and of course i say simply with my tongue firmly in my cheek, speaking as an architect) the consultant designers. VW were the builders. construction contractors no less. @JeffBowlsby knows what i am saying. i look upon the whole thing as a classic architect designed building arrangement. sure the architect designs it. and the structural engineer makes sure it stands up and gets creative as well. and then it gets handed to the builder. i reckon VW can give you a full birth certificate. if you give them the engine number they will go so far as to confirm it was the engine it was built with etc. but they won't tell you the engine number it was built with straight up. they want you to give them engine number etc and then they confirm or tell you its not the correct engine, gearbox. karmann has the factory records for sure. complete. i seriously doubt porsche has any real records on the 4s except what porsche north america might have held as shipping order documents. but not build sheets? and VW can give you a full birth certificate for a karmann ghia. so they must be accessing karmann factory archive documents. or even VW central management records sent out to the karmann factory. try it. see if you can get one. if you do let me know. its way cheaper than a porsche C of A as well. if you succeed i will do it for mine from far off australia. (IMG:style_emoticons/default/beerchug.gif) |
| chmillman |
Oct 26 2025, 03:52 AM
Hmm, very interesting idea! AMAG - official VW importer and reseller in CH - has an “AMAG Classic” division, I will start with a query to them… Mal sehen…
Lo-Fi Version | Time is now: 26th October 2025 - 10:35 AM |
