| Literati914 |
Oct 29 2025, 03:58 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,124 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Silly question probably.. but I have no experience with these so I'll ask anyway, I currently need to have a couple small items pressed at the moment (roll pin at the transmission shift input and it's corresponding seal). I tried hammering the pin out with a hammer and punch but it didn't budge. Would one of the hand-lever activated, table top 1-ton presses be enough to get this done? I've got another couple of project cars that will need items pressed too, so I figured I might just invest in a small one. It's really hard to find anyone with the equipment and/or willing to bother in my area. A second hand unit would be less than they'd charge me anyway. Are these fairly effective or no?
| Shivers |
Oct 29 2025, 04:40 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,158 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
There is a roll pin press, see link. https://www.zoro.com/ezred-roll-pin-tool-ez...AiABEgLHNPD_BwE
I bought a Harbor Freight 12 ton for 149.00, should do all I need. @Literati914 |
| mepstein |
Oct 29 2025, 05:36 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,196 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
There is a roll pin press, see link. https://www.zoro.com/ezred-roll-pin-tool-ez...AiABEgLHNPD_BwE I bought a Harbor Freight 12 ton for 149.00, should do all I need. @Literati914 Strange issue. I've disassembled dozens of trans at our shop and always used a punch and hammer. |
| Superhawk996 |
Oct 29 2025, 05:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,498 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
One ton really isn’t much force.
Do you have a decent 8” bench vise? A decent vice will generate 2000 - 3000 lbs of clamping force easily. As always - use heat to your advantage. I’ve been playing the fix it game all my life and haven’t needed an arbor press yet. Per Shivers - a hydraulic press is a game changer if you have the space and not crazy expensive either. |
| Shivers |
Oct 29 2025, 05:41 PM
There is a roll pin press, see link. https://www.zoro.com/ezred-roll-pin-tool-ez...AiABEgLHNPD_BwE I bought a Harbor Freight 12 ton for 149.00, should do all I need. @Literati914 Strange issue. I've disassembled dozens of trans at our shop and always used a punch and hammer. I did mine the same way. A drift the correct size has always worked. Maybe it was goobered up by a previous wrench. |
| VaccaRabite |
Oct 30 2025, 05:42 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,807 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I've had roll pins rust into place before to the point where hammer and drift were not successful. The pin in question was the roll pin in the clutch pedal.
I ended up saying fuch it and buying a rebuilt cluster from Bruce. Every time I've had need of a press, I've found a way around buying one. Usually heat and penetrating oil are all I need. Zach |
| 930cabman |
Oct 30 2025, 05:46 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,315 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
| Tom1394racing |
Oct 30 2025, 07:22 AM
Member ![]() ![]() Group: Members Posts: 485 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States
I bought a 20-ton Harbor Freight press for $100 at an estate auction. I have found it to be an invaluable tool. I have used it for removing and installing wheel bearings, suspension bushings, crankshaft gears, and even stubborn rusted bolts in exhaust parts. Much safer and more controlled than the hammer.
| Literati914 |
Oct 30 2025, 11:56 AM
Strange issue. I've disassembled dozens of trans at our shop and always used a punch and hammer. I got so focused on the roll-pin on the "ball / cup" end of the shifter console (which refuses to move with my hammer and drift), that I forgot there was another roll-pin on the other end, the selector end. The hammer and drift moved that roll-pin with no trouble. Thanks guys. |
| mepstein |
Oct 30 2025, 12:35 PM
Strange issue. I've disassembled dozens of trans at our shop and always used a punch and hammer. I got so focused on the roll-pin on the "ball / cup" end of the shifter console (which refuses to move with my hammer and drift), that I forgot there was another roll-pin on the other end, the selector end. The hammer and drift moved that roll-pin with no trouble. Thanks guys. Glad you got it figured out. We have that 20 ton HF at our shop. It works fine but lacks the ability to adjust the width of the crossbar. We are doing about two trans a month but that will probably increase once we move into the new shop. We’ll be getting a better press shortly. |
| Shivers |
Oct 30 2025, 05:18 PM
Strange issue. I've disassembled dozens of trans at our shop and always used a punch and hammer. I got so focused on the roll-pin on the "ball / cup" end of the shifter console (which refuses to move with my hammer and drift), that I forgot there was another roll-pin on the other end, the selector end. The hammer and drift moved that roll-pin with no trouble. Thanks guys. Hahaha, oh shoot, I guess I should have said something. I figured you had your reasons. Glad it worked out. |
| bkrantz |
Oct 30 2025, 08:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,526 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I bought a 20-ton Harbor Freight press for $100 at an estate auction. I have found it to be an invaluable tool. I have used it for removing and installing wheel bearings, suspension bushings, crankshaft gears, and even stubborn rusted bolts in exhaust parts. Much safer and more controlled than the hammer. I have had some kind of press for 25 years, and now could not live without one. For lots of jobs a press might be optional--but way easier. For other jobs, the press is the RIGHT way, and make-shift methods are asking for trouble. And with other accessories it can do more. I recently bought a press brake and can make sweet bends in medium weight sheet metal. |
| ChrisFoley |
Oct 31 2025, 04:31 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,016 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
I have a one ton arbor press which I use regularly on small components of my products, but I almost never find it useful for vehicle repair work.
Lo-Fi Version | Time is now: 2nd November 2025 - 01:16 PM |
