> Suspension setup help
75ninefourteen
post Oct 31 2025, 02:02 PM
I've been researching the 914 suspension (factory setup) due to the fact I noticed my car was lower on the driver side. I want to make adjustments prior to getting new tires an know this should be set before getting an alignment. Plus I would like to try and understand the modifications made by POs.
Details:
* '75 914 with 1.8
* Springs/Shocks replaced on 6/23/00 at 45,881 miles (~68k miles now)
* Springs changed to 100#
* Bilstein Shocks (F4-B46-0179-H0 == 24-001793)
* Shock is set to the top most groove (6 grooves total)
As of right now, I've adjusted to get fender heights match side to side when comparing the front or the rears. I should also mention the rear fenders are about 1.5" from the top of the wheel rim.
Taking a measurement from the "donuts" on the underside the front sits 1 inch higher than the rear. (Front == 6.75" and Rear == 5.75"). I still have some adjustment left in the front to lower, but not sure how low the car should be lowered. My understanding is the rear should be slightly higher.
Center of the wheels measure right at 12" and the torsion cap is 7.5" (center to ground). Based on the manual I should technically need to raise the front to get back to within factory specs, but I know the car isn't running factory springs.
From what I've gathered, this current setup might have been more for autoxing rather than street driving.
All that said I am trying to get some clear answers about factory setup:
* What is stock height and where should I get a measurement from?
* To raise the rear suspension height, is to adjust the shocks and spring location? I have spare shims for the trailing arm, but if I am following correctly this is only for alignment purposes.
* What's a good way to see if rear shocks/springs are wore out? Pushing on the front bumper. I feel like the fronts should be replaced. So my guess is the back is probably due to be replaced after 25 years.
Thanks for the help in advance.
Replies(1 - 13)
75ninefourteen
post Oct 31 2025, 02:08 PM
Thought I would add a couple pics for reference
rjames
post Oct 31 2025, 03:53 PM
I'm made of metal
IIRC, the stock height is taller than most like.
I adjusted mine to look like most of the other 914s I see, so I can't give you exact dimensions of what you should be aiming for. Your rear ride height is similar to mine, but my front looks lower. I like for the front to be a little lower than the back, but not so much that it stands out.
What I can offer is that you need to ensure that you're car is on level ground to get it right. Any adjustment you make on one corner can (and likely will) impact all other corners. If you're not on level ground to start with, you'll be making adjustments in the dark.
bkrantz
post Oct 31 2025, 07:49 PM
You might know this, but the factory spec for front ride height is based on the angle the A-arm makes. And the rear was not adjustable.
Be careful using fender openings for comparing ride height since even the brand new cars had some variation from side to side.
Montreal914
post Oct 31 2025, 08:36 PM
Weren't the north american cars set higher in the front due to headlight minimum height regulations? (IMG:style_emoticons/default/confused24.gif)
IronHillRestorations
post Nov 1 2025, 07:54 AM
I. I. R. C.
The factory ride height is the difference between the center of the front wheel and the center of the torsion spring. The stock number is 90mm +\- 5mm. This is measured with a half tank of fuel and the driver’s weight in the left seat.
Raise the front to unload the torsion springs to make adjustments, otherwise you can break the adjuster screws.
I like the front of the car to be a little lower. I measure along the bottom pinchweld, as far rear before it curves up, and as far forward before it curves in towards the center. About 1/4” lower in front seems to work well. You can go a little lower but never higher in the front.
75ninefourteen
post Nov 1 2025, 08:41 AM
Thanks for the feedback. I know that the front should be lower than the rear. I just stopped at this point to see where I was at with measurements. And based on the manual and using calculating out the "proper" height I was that I was already around an 1.25" lower than what was recommended in the book. Main item I wanted to be sure of is that I'm not to lower and should just match up with the height of my rear. And from what I can see its adjusted to give max height now.
Initially when I started, the front driver side adjustment was all the way at the top making it as low as possible. Which made the car visibly lower on that side. I basically adjusted to match the passenger side height were it was. I am on level ground and was only using fender height as a reference to see if there was sag anywhere. I was using underbody points as the main reference.
I think I will start off by getting a full tank of gas in the car before I make any more adjustments. I think it only has about a quarter of a tank now.
I plan to swap out the rear shocks since they're 20 years old at this point. Fronts as well, I think they might be older since I didn't see any notes on them being updated.
Thoughts on changing out the rear springs as well? Any recommendations? From what I have read the 100# rating is a nice upgrade? I see 914Rubber sells a set.
75ninefourteen
post Nov 6 2025, 12:24 PM
I was able to adjust the ride height in the front to be about 1/4" lower than the rear as it sits now with a full tank of gas.
One other question I have is there any markings on the front struts to let me know what inserts I should get for replacements? I took a quick look but didn't see anything. They are black with no markings. Right now I am assuming that since I have the Bilsteins on the rear that those are on the fronts as well.
Cairo94507
post Nov 6 2025, 01:28 PM
Michael
Hello @75ninefourteen - Just a word of caution, check to make sure you are not bottomed out on the front adjustment. Ideally, you want that resting in the mid-point of the available adjustment. If you are at the extreme of the lowering adjustment, best to re-index the torsion bars. (IMG:style_emoticons/default/beerchug.gif)
Also, a great time to check all of the suspension attachment points to make sure you don't have a rear suspension console that is cracked. on my 2nd 914-6, I had a cracked passenger rear suspension console we had to repair. I drove the snot out of that car and that suspension point cracked. We repaired it and checked the other side too. This was back around 1986, so it was not a hell-hole, battery acid issue. (IMG:style_emoticons/default/biggrin.gif)
75ninefourteen
post Nov 6 2025, 02:01 PM
@Cairo94507 Thanks for that note about the front adjustment and being bottomed out. I am close to being bottomed out so I will probably need to look at re-indexing. I will be sure to check attachment points.
First I need to check shocks/struts all around and make sure they're still good since they're 20 years old. I am assuming its time for a replacement and see how that affects the ride height first.
75ninefourteen
post Nov 9 2025, 01:48 PM
After a few test drives for the shifter and linkage, I wasn't happy with the ride quality of the car. I decided to take a look at the rear suspension first. Turns out the shocks are wore out and the shock can extend more than the spring. Didn't even need to have a compression tool to disassemble.
My plan is to go with the 100lb spring from 914 Rubber that I believe are standard length. I'm trying to decide between Koni or Blistein B6s. My plan is to have a weekend cruiser over a track car. Maybe one day I'll try going to a track.
From what I've gathered searching, which brand to go with seems to be more of a preference from what I can tell. I like the idea of having some adjustment with the Koni shocks. But also like more options for height settings with the B6s. Since my car has been riding low. But I think going with the standard springs that is probably a non issue.
That said, I've got a few questions since I'm new to 914s.
- Does my front struts (last 3 pics) limit me to one brand or another? I can't find any distinguishing marks or paperwork they've been changed. And I keep reading posts that some fit and others don't in the front. From what I have read since they are black, their the Boge style.
- Anyone have experience with 914 rubber springs?
75ninefourteen
post Jan 19 2026, 01:51 PM
I've swapped out the rear shocks for new Bilsteins (B6) with new springs (100# 914Rubber). Old stuff was shot and springs were actually a different size (pic for reference). I could use some help for those running Bilsteins on their car or what I should aim for to get stock ride height.
What notch should I put the circlip at? I thought I saw something that said 4th from the bottom, but old setup had it at the very top. Currently I have it in the 5th notch. That gives me around 2.75" of rear tire showing. Originally I was around 1.5 - 1.75".
Trying to understand what moving the spring to higher vs lower notch will actually do? I assume if I move it to a higher notch get some rear height added since the spring would be more pre-loaded. What does this do to the ride versus having it lower? If I am just street driving, I assume a coilover kit would be overkill?
From a previous comment I need to look at re-indexing the front since I am running out of adjustment to lower the front end to be 1/4-1/2 lower.
bkrantz
post Jan 19 2026, 08:48 PM
Changing the pre-load does not change the spring rate.
DennisV
post Jan 20 2026, 08:59 AM
QUOTE(75ninefourteen @ Oct 31 2025, 12:02 PM) *
Has anyone written a document, or done a video, to guide someone through initial suspension setup? I realize there are a lot of specs in the workshop manual, but I assume there is a logical order of operations. Also some baseline settings (i.e., set your tie rod with 10mm of thread exposed) that would get you in the ballpark. If this resource exists, I haven't found it.
- Lo-Fi Version Time is now: 12th March 2026 - 06:07 AM
