> 100 micron pre pump fuel filter, 75 front pump location
rfinegan
post Nov 4 2025, 01:21 PM
I am looking to route my fuel lines one more time (no kinks). While in there I will change my line to AN fittings and braided fuel lines. Does any one have a recommendation for a Pre fuel filter of 100 microns? I have a good post hi pressure filter in place already
Something like this?
https://www.summitracing.com/parts/sum-2301...OlOTtQ0t6Qf48Fc
Replies(1 - 19)
rfinegan
post Dec 1 2025, 01:13 PM
Evil works fuel filter and 6-an linesAttached Image
still more lines to make....
JamesM
post Dec 1 2025, 10:47 PM
If you are updating things:
NO pre pump filter aside from the tank screen.
10 micron high pressure post pump filter
I've been using these but you can get that one you posted with a 10 micron element as well.
https://www.summitracing.com/parts/sum-230123b
Cleanest fuel with the least amount of flow restriction. Late style bosch 2 port pumps will handle this no problem. you want the step up from the 10mm line to the 12mm line as close to the tank as possible. Or just change out the tank fitting itself.
and before anyone bitches about not having a pre pump filter, this is the configuration Volkswagen moved to in the 80s with this pump to address cavitation on the intake side. you want as little restriction as possible between the tank and the pump.
JamesM
post Dec 1 2025, 10:48 PM
I am assuming this is a fuel injected car? if not than YMMV, not sure what all the various carb pumps can accommodate.
rfinegan
post Dec 2 2025, 12:11 AM
QUOTE(JamesM @ Dec 1 2025, 11:48 PM) *
Yes, This is a new Wabro pump and will be 2056 fuel injected too. I will post the spin on 10 micron filter pics under the battery tray/ fire wall to complete the system (ALL PTFE lines)unless i can find room under the tank too( keep out of the heat)?
Thanks for the tips
100 micron is like a large tank screen to catch the big chunks to protect the pump a little. The 10 micron will keep the injectors clean.
6-an =3/8 id PTFE, so should be larger inlet diameter and improvement and reduced bottlenecks kinks?
VaccaRabite
post Dec 2 2025, 08:28 AM
En Garde!
@rfinegan
For the front trunk fuel line kinks, I just bent up some hard lines and ran them that way. Way, way easier, and 100% kink free.
Zach
Mitox
post Dec 2 2025, 09:30 AM
I purchased one with an integrated cut-off valve to simplify cleaning/changing the filter element. The price just increased another $20 though.
https://www.hyperracing.com/HBS-Fuel-Filter...-Shut-Off-Valve
campbellcj
post Dec 2 2025, 10:30 AM
I can't Re Member
I have a Canton filter up front post-pump; all AN-6 plumbing. Has worked well and is clean-able.
rfinegan
post Dec 30 2025, 01:19 PM
spin on fuel filter installation
rfinegan
post Dec 30 2025, 01:21 PM
I added spin on fuel filter under the trunk springs on the pass side with rivet nuts and swivel 1/4 pipe to 5/16 barbs for the fuel supply lines.
I think this is going to work out well...
rfinegan
post Dec 30 2025, 01:25 PM
filter with swivel 90 degree barbs
rfinegan
post Dec 30 2025, 01:27 PM
another
rfinegan
post Dec 30 2025, 01:29 PM
hoses snd clamps
rfinegan
post Dec 31 2025, 08:39 AM
For summary, The 75 now has a 100 micron pre filter into a Walbro pump and 6 AN PTFE braided lines and a new tank. A spin on 6-8 micron filter in the engine compartment for EZ service, located by the fresh air inlet so temp should not be an issue
jim_hoyland
post Dec 31 2025, 09:12 AM
Get that VIN ?
As to “ NO pre pump filter aside from the tank screen” I have wondered why this is a good idea. Suppose that screen get clogged up: And your out on an open road ?
Geezer914
post Dec 31 2025, 09:27 AM
Geezer914
Mount your pump and filter under the steering rack panel. You won't have to pull the tank to service the pump or fuel filter.
Superhawk996
post Dec 31 2025, 12:24 PM
QUOTE(jim_hoyland @ Dec 31 2025, 11:12 AM) *
JamesM addressed it correctly in post #3.
If you’re clogging the tank screen or a 100 micron filter you have far bigger problems to worry about.
Any fuel going into the tank from a fuel pump is already filtered to 10-30 micron depending on what filters the filling station is using.
JamesM
post Jan 1 2026, 10:17 PM
QUOTE(jim_hoyland @ Dec 31 2025, 08:12 AM) *
No screen at all is also an acceptable (and possibly preferable) option. This is how it was done on Vanagons.
You want the least amount of restriction pre pump. Shortest, fatest, straightest suction lines possible with no filters restricting flow. Vacuum on the inlet side of the pump can cavitate the fuel which leads to a noisier fuel pump as well as potentially causing damage/shorter life to the pump. Depending on the condition and routing of the fuel lines it can also cause the feed line to collapse on itself causing fuel starvation.
Injectors require filtered fuel for long life the pump doesn't, it needs unrestricted fuel flow.
Superhawk996
post Jan 2 2026, 06:57 AM
QUOTE(JamesM @ Jan 2 2026, 12:17 AM) *
Injectors require filtered fuel for long life the pump doesn't . . .
Maybe . . .
If you’re going to delete all pre-filtration you better know what type of fuel pump you’re using (turbine, gearotor, or rollervane, diaphragm or vibrating plunger like a Facet).
Turbine pumps are not forgiving if run without pre-filtration.
A 100 micron pre-filter doesn’t cause any significant restriction to the pump inlet nor does the OEM sock.
jim_hoyland
post Jan 2 2026, 05:45 PM
Get that VIN ?
What is the micron filtering for these ?
- Lo-Fi Version Time is now: 2nd April 2026 - 09:24 AM
