> Engine Mod Reminder
DennisV
post Nov 5 2025, 09:24 AM
Does anyone have a clever tip for how to remind yourself, and potentially others, about engine mods without being too overt about it?
For example, our 914-6 engine has an E-grind on the cam instead of the stock T profile.
The only thing I've seen was on our car. It's on the support beam on the underside of the engine lid. I don't love it, but it's somewhat hidden and effective. Wish they hadn't screwed it on.
Better ideas?
P.S. No. The 911S engine didn't come with the car. (IMG:style_emoticons/default/sad.gif)
Replies(1 - 7)
post Nov 5 2025, 01:38 PM
914-6 GT in waiting
Write it down and put it with the title.
DennisV
post Nov 10 2025, 09:57 AM
QUOTE(mepstein @ Nov 5 2025, 11:38 AM) *
Title will go in safe deposit box and no one will ever see it.
I think I'll try to create a gold foil sticker and put it on the engine lid with the factory ones. Maybe something like this:
GregAmy
post Nov 10 2025, 11:24 AM
QUOTE(DennisV @ Nov 5 2025, 10:24 AM) *
Better ideas?
Don't you keep a file folder of receipts and such? If so, and paper is your thing, write it all down and put it in that folder.
Are you worried that you'll pass away and the subsequent owner won't get that file folder? Put a note in your will with the location of the folder. Let your spouse and executor know about it.
I personally scan all receipts to PDF and write all the details down in Excel and TXT files and keep them on the home server. I do it mostly for myself, as you can damn well bet in a few years I'll need to remind myself about something I did... - GA
DennisV
post Nov 10 2025, 11:32 AM
QUOTE(GregAmy @ Nov 10 2025, 09:24 AM) *
Yep. I have a massive folder.
Nope. I'm worried that I, or someone else, will do work on that engine and assume it's stock and set the cam timing for a 911 T.
gereed75
post Nov 10 2025, 12:20 PM
To set the cam timing the cam covers must come off. You can then inspect the cams. they are numbered on the end that is visible.
You pretty much can’t set the timing without knowing what cams are in there. It is not something that you do as part of routine maintenance. It is done once when the engine is built and not redone unless there is a problem. Likely any reasonably competent mechanic who is able to diagnose the problem, remove the engine and take off the cam covers will know to check the cams.
I like the sticker, it’s cool but probably not necessary
GregAmy
post Nov 10 2025, 10:15 PM
QUOTE(DennisV @ Nov 10 2025, 12:32 PM) *
So then...just tell them before they do?
(IMG:style_emoticons/default/drunk.gif)
infraredcalvin
post Nov 10 2025, 10:45 PM
Distracted Member
This happened with my car, had to tear it all the way down to crank to see what was in there…
And still cant find any power… (IMG:style_emoticons/default/headbang.gif)
- Lo-Fi Version Time is now: 12th November 2025 - 12:58 AM
