> Rear 5-lug rotor and caliper - identify?, Just want to make sure what I've got before I order pads
chmillman
post Nov 5 2025, 09:48 AM
Region Association: Europe
As per previous threads, my car has had a 5-lug conversion - I think correctly done. The front hubs/rotors/calipers are 914-6/early 911 ones as far as I can tell (ATE calipers), I therefore assume the rear hubs/rotors/calipers might also 914-6 or similar? Can someone confirm? TIA
Just for laughs, Google's Ai analysis of the photo tells me it's from a Nissan Primera P12... (IMG:style_emoticons/default/lol-2.gif)
Replies(1 - 7)
peteyd
post Nov 5 2025, 11:27 AM
those are 4 cylinder calipers. later ones with the dual bleeders.
chmillman
post Nov 5 2025, 04:12 PM
OK, so they changed the hubs and rotors for 5-lug… but the 5 lug rotor has basically the same dimensions overall as the 4-lug one, so it fits with the stock -4 caliper? Is that how it works?
brant
post Nov 5 2025, 04:21 PM
QUOTE(chmillman @ Nov 5 2025, 03:12 PM) *
pretty close...
if you stay with non vented rotors... the OD of the 5bolt rotor gets turned down a tiny amount... to work on a 4 cylinder set up.
chmillman
post Nov 6 2025, 05:53 AM
QUOTE(brant @ Nov 5 2025, 11:21 PM) *
pretty close...
OK, that's interesting, thanks... Just trying to understand all what has been done here. The disc does have a part number on it - 901 352 401 18 - and it does appear to be a 914/6 disc...
The OD of the rotor part is around 285mm (11.2") as well as I could measure while still on the car. From the traces on the edge of the rotor, it appears that it might even be rubbing slightly on the spring clip... So maybe these weren't turned down?
Anyone have the outer diameter specs for a /4 rear disc vs a /6 disc? Doesn't look like much could or should be turned off, the pad-swept area on the rotor starts in about 3mm from the outer edge.
Also have been unable to find a part number on the rear caliper, just the ATE logo... Here's what it looks like from the inside. Definitely dual bleeder fittings.
mate914
post Nov 6 2025, 05:58 AM
Matt
914-6 = 911T same rear rotor until the rear vented discs came out.
Montreal914
post Nov 6 2025, 08:13 AM
Here you go. (IMG:style_emoticons/default/smile.gif)
914 Rear rotor:
solid
diameter: 282mm
thickness: 9.4 (or 9.5?)mm
caliper piston dia: 33mm
914-6 Rear rotor:
solid
diameter: 286mm
thickness: 10.4mm
caliper piston dia: 38mm
914-6 GT Rear rotor:
vented
diameter: 286mm
thickness: ?
caliper piston dia: 38mm (same caliper as 914-6 with a spacer)
No longer available but there are ways around
chmillman
post Nov 6 2025, 09:49 AM
QUOTE(Montreal914 @ Nov 6 2025, 03:13 PM) *
914 Rear rotor:
solid
diameter: 282mm
914-6 Rear rotor:
solid
diameter: 286mm
thickness: 10.4mm
vented
diameter: 286mm
thickness: ?
OK, great info, thanks much! So it looks like /4 calipers manage to accomodate the extra 1mm thickness of the /6 rotors - unless the pads were shaved in my case - but the extra 4mm in diameter is just a tad too much. Too bad. Options are change the calipers or remove the rotors and turn them down. Unfortunately my toolmaker's lathe is too small for me to be able turn the rotors myself.
- Lo-Fi Version Time is now: 6th November 2025 - 04:19 PM
