| Geezer914 |
Nov 5 2025, 03:23 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,115 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
What is the best way to separate CV joints from the transmission flange? Mine are really stuck. Sharp putty knife and a hammer? The CV joints are from PMB and no gasket was used, just sealer. (IMG:style_emoticons/default/headbang.gif)
| Dave_Darling |
Nov 5 2025, 07:46 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,287 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Yup, putty knife. Sometimes tapping on the side of the CV Joint with a soft-faced mallet can break the "sticktion".
--DD |
| bdstone914 |
Nov 6 2025, 03:16 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,163 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What is the best way to separate CV joints from the transmission flange? Mine are really stuck. Sharp putty knife and a hammer? The CV joints are from PMB and no gasket was used, just sealer. (IMG:style_emoticons/default/headbang.gif) I rotate the axle until the roll pins are in thec12 and 6 o'clock position then hit the axle shaft to start the cv to break loose from the flange. Or drive a screw driver blade thru the gasket to start it to break loose. |
| 930cabman |
Nov 6 2025, 05:56 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,320 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Yes, thin screwdriver lightly tapping. NEVER should this connection be sealed with any type of sealer, never
Lo-Fi Version | Time is now: 6th November 2025 - 04:19 PM |
