> Shifter loose, Need advice
Ebradley
post Nov 7 2025, 01:22 PM
Hi
The shifter on my 74 (2.0) is loose and won’t go into gear because it’s too wobbly. I’m guessing it’s the shifter bushing, but I’m not sure. Are these bushings pretty easy to change? Thanks for the advice.
Replies(1 - 5)
GregAmy
post Nov 7 2025, 03:24 PM
There's three primary places to check:
- The bushings at the side shifter console going into the transaxle. They're under the black rubber/plastic boot;
- The two black bushings in the u-joint in the engine compartment just aft of the firewall;
- The bushing holding the shaft going through the firewall.
All are common failure areas but all are easy, and relatively economical, to repair.
Go check those out.
EDIT
Side shifter bushings:
https://www.pelicanparts.com/More_Info/9144...mp;SVSVSI=18408
https://www.pelicanparts.com/More_Info/9114...mp;SVSVSI=18408
U-Joint Bushings
Improved replacement for both of the above: https://tangerineracing.com/shop/ols/produc...ift-linkage-kit
Firewall bushing
https://www.pelicanparts.com/More_Info/9144...sCat=Y&nb=Y
Improved alternative: https://tangerineracing.com/shop/ols/produc...ift-rod-bearing
emerygt350
post Nov 7 2025, 04:06 PM
And the glue that holds the stick in goes as well...
And if the cone screws have come loose...
Rube Goldberg would be proud.
GregAmy
post Nov 7 2025, 04:40 PM
QUOTE(emerygt350 @ Nov 7 2025, 05:06 PM) *
lol yup.
But that's the price you pay to put the engine in the "correct" location... - GA
Ebradley
post Nov 7 2025, 05:05 PM
Thanks for the input
Patrick_139
post Nov 7 2025, 09:03 PM
If it is the coupler bushing I found this video to be helpful. I replaced all of the bushings and between videos and information on this site I found it to be fairly easy considering I am low skilled at auto repair.
Good luck
https://www.google.com/search?sca_esv=ae9ad...hdfsxoPh54,st:0
- Lo-Fi Version Time is now: 8th November 2025 - 09:44 AM
