| rfinegan |
Nov 9 2025, 08:30 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,136 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
Any one use the compression fitted fuel line ends to adapt the pipette on the fuller tank to a PTFE 6AN fuel line?
Feed back and experience appreciated.... |
| bdstone914 |
Nov 9 2025, 09:20 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,178 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You can tap the threaed nipples on the tank1/4 FPT. Install pipe threadcto 6an. You loose the sock filter in the tank. Some VW parts suppliers have one of the nipples with 6AN fitting.
I have considered adding an externally industrial cleanable filter outside the tank. |
| Graydingo |
Nov 9 2025, 10:02 AM
Member ![]() ![]() Group: Members Posts: 81 Joined: 12-August 22 From: Las Vegas Member No.: 26,768 Region Association: Southwest Region |
I did this. I converted 911 Carrera hardlines to the engine bay (near the filter by cutting the pipes square and installing 6AN PTFE lines. Holds well.
| rfinegan |
Nov 9 2025, 10:51 AM
great info thanks for the tips
yes the plan is a Much better pre filter and ptfe 6an lines this may work and clean things up for no leak/no kink lines https://www.amazon.com/gp/product/B08SGVYFF...DH1PL&psc=1 this is wrong AI fails me again |
| Jack Standz |
Nov 9 2025, 11:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 590 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Yes, did this using -6AN fittings from IIRC air-cooled.net to the tank (no longer in business) and installed PTFE fuel lines and fittings.
Also, Chris Foley of Tangerine Racing can TIG weld AN fittings on the stainless fuel lines he sells (take your pick, front or rear - we chose rear). Edit: Actually and thinking about it some more, don't think AN fittings welded on the stainless fuel lines will pass the front/rear firewall without some opening up of the holes. Which is why we only have AN fittings on the rear of the fuel lines. |
| Literati914 |
Nov 9 2025, 06:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I wonder if one of these would work:
https://www2.cip1.com/c26-201-209-6/ https://www2.cip1.com/jc-4560-0/ |
| KSCarrera |
Nov 10 2025, 01:48 AM
Member ![]() ![]() Group: Members Posts: 340 Joined: 31-January 19 From: UK Member No.: 22,846 Region Association: England |
CB Performance sell 6AN (-6) and 8AN (-8) fittings that are designed exactly for this, too...
https://www.cbperformance.com/product-p/3288.htm https://www.cbperformance.com/product-p/3289.htm |
| rfinegan |
Nov 10 2025, 06:18 AM
THANK YOU
I did not get the correct ends. this was wrong too and got the ones from CBP |
| jd74914 |
Nov 10 2025, 10:46 AM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,862 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Any one use the compression fitted fuel line ends to adapt the pipette on the fuller tank to a PTFE 6AN fuel line? Feed back and experience appreciated.... Seems like you have a better path now but just in case you have future need there is only one place I know of sells these metric compression to to 37 degree adapter fittings... FAV Fittings FCF/MCJF/5I-8T https://favfittings.com/instrument-fittings...onnector-jic-2/ They are a real company. (IMG:style_emoticons/default/laugh.gif) No idea on what the lead time for this kind of stuff is though. |
| rfinegan |
Nov 18 2025, 10:19 AM
CB Performance fittings for the Win! Perfect fit
Lo-Fi Version | Time is now: 19th November 2025 - 12:58 AM |
