| jim_hoyland |
Nov 9 2025, 09:41 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,938 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Just need the wires color that runs from the switch to the rear relay board(
and the wire from the fuse panel to the switch. |
| Robarabian |
Nov 9 2025, 10:13 PM
914 A Roo ![]() ![]() ![]() Group: Members Posts: 723 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California
Jim,
I can try to crawl under my dash this week, I have a 72 with a defroster. Unless someone else chimes in with the info you need. Rob |
| jim_hoyland |
Nov 10 2025, 09:24 AM
Thanks Rob; be careful… (IMG:style_emoticons/default/smile.gif)
| JeffBowlsby |
Nov 10 2025, 09:39 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,117 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
(IMG:style_emoticons/default/biggrin.gif) I have a couple of defroster window harnesses available FS if anyone needs one.
Attached File(s)
914_ACC_RearWindowDefroster.pdf ( 396.93k )
Number of downloads: 17 |
| jim_hoyland |
Nov 10 2025, 05:44 PM
| Dave_Darling |
Nov 10 2025, 06:48 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,289 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Wow, Phil Sparta. Haven't seen that name in quite a while...
--DD |
| jim_hoyland |
Nov 10 2025, 07:57 PM
Lo-Fi Version | Time is now: 12th November 2025 - 12:58 AM |
