| sixaddict |
Nov 14 2025, 08:37 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,051 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
Pelican has 20% off deal on PMB 914-6 rear calipers. …….just saying.
| mepstein |
Nov 14 2025, 08:56 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,532 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
$796/pair - That's a great deal.
| Montreal914 |
Nov 14 2025, 11:30 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,052 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Thank you for sharing! I was at the last click of my purchase on Pelican, then went to check out PMB's website just to see... (IMG:style_emoticons/default/idea.gif)
PMB also has the Brake Friday sale with the same price. (IMG:style_emoticons/default/cheer.gif) $820 to my door (no tax). Purchase done! (IMG:style_emoticons/default/sunglasses.gif) Again, thank you Terry!! @sixaddict (IMG:style_emoticons/default/beerchug.gif) |
| JmuRiz |
Nov 14 2025, 12:18 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,620 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
My solid modified /4 rears were good...but vented would be better right?
| mepstein |
Nov 14 2025, 12:50 PM
My solid modified /4 rears were good...but vented would be better right? Probably don’t really need vented rears on a 914-6 unless you are descending a mountain road with a lot of sharp turns but I like the look so that’s what I’m using. Last time I looked, it was easier to find vented rotors than solid ones. |
| burton73 |
Nov 14 2025, 01:40 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,977 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
My solid modified /4 rears were good...but vented would be better right? Probably don’t really need vented rears on a 914-6 unless you are descending a mountain road with a lot of sharp turns but I like the look so that’s what I’m using. Last time I looked, it was easier to find vented rotors than solid ones. All I know is it stops like a mother and it looks great. Factory 6 calipers and PMB vent kit Best Bob ![]() |
| Montreal914 |
914-6 GT rear rotors are P/N 901-352-041-12 and NLA. Very hard to find.
I believe you are referring to rotors 901-352-041-14 which are the 911 rotors that have a 290mm dia. These should be turned down to 286mm dia to match the 914-6 GT ones. I assume the offset is OK since they have been succesfuly used. (IMG:style_emoticons/default/smile.gif) |
| JmuRiz |
Nov 14 2025, 02:12 PM
My solid modified /4 rears were good...but vented would be better right? Probably don’t really need vented rears on a 914-6 unless you are descending a mountain road with a lot of sharp turns but I like the look so that’s what I’m using. Last time I looked, it was easier to find vented rotors than solid ones. All I know is it stops like a mother and it looks great. Factory 6 calipers and PMB vent kit Best Bob ![]() Those drilled ones do look good, the ones on PMB don't show that as an option. I do have drilled in the front (with boxster calipers). Maybe I should write Eric and see what he says....other than 'get your ass busy and put that car together already'... |
| Ninja |
Nov 14 2025, 02:23 PM
Member ![]() ![]() Group: Members Posts: 181 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
https://pmbperformance.com/products/porsche...nversion-bundle
Checked PMB, they have a killer GT kit. Rotors have been machined down (outer diameter) and calipers have "special mounting kit" So, diameter and offset have to be delt with. Or you could just buy the kit. Pretty good value in my book! Only thing I would add is cross drilling which Mr. Burton has proven available... |
| burton73 |
Nov 14 2025, 09:02 PM
My solid modified /4 rears were good...but vented would be better right? Probably don’t really need vented rears on a 914-6 unless you are descending a mountain road with a lot of sharp turns but I like the look so that’s what I’m using. Last time I looked, it was easier to find vented rotors than solid ones. All I know is it stops like a mother and it looks great. Factory 6 calipers and PMB vent kit Best Bob ![]() Those drilled ones do look good, the ones on PMB don't show that as an option. I do have drilled in the front (with boxster calipers). Maybe I should write Eric and see what he says....other than 'get your ass busy and put that car together already'... The fronts are early S Calipers that where on my car when it went to PMB That was the trick set up back in early 1970 |
| mepstein |
Dec 5 2025, 03:49 PM
I got a set to try out.
Attached thumbnail(s) |
| Montreal914 |
Dec 5 2025, 08:56 PM
I must have lucked out as mine arrived fully dressed! (IMG:style_emoticons/default/smile.gif)
Ordered directly from PMB, $825 to my door. EDIT: These are the non-vented ones. ![]() |
| Cfletch |
Dec 6 2025, 12:04 AM
Member ![]() ![]() Group: Members Posts: 231 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
I have these in my car but in stock 6 form, cant wait to drive and test it out!
| mepstein |
Dec 6 2025, 07:01 AM
The early 930's used a S caliper front and M caliper rear. These 914-6 rear calipers are basically an M caliper with a parking brake. The 930 weighed 2650lbs +++, compared to our light weight cars. Unlike the heavy turbo's, it should be near impossible to overheat our rear rotors, even when they are solid disks.
Lo-Fi Version | Time is now: 12th March 2026 - 02:09 AM |
