> URO Parts Rear Stabilizer Bar Install Kit 91450125910K
UROpartsman
post Nov 14 2025, 01:26 PM
URO Parts' Rear Stabilizer Bar Install Kit 91450125910K makes it easier to install a rear sway bar in your 914, just add a bar and end links! (Welding and painting is required.) This kit is now available from Porsche specialists such as:
Auto Atlanta in Marietta, GA:
914 501 259 10K: STABILIZER BAR INSTALL KIT R91450125910K
Rear Kit Contains:
  • (2) 914 501 259 10 Mounting Bracket
  • (2) 914 501 532 71 Reinforcement
  • (2) 901 333 793 03 Bushing
  • (2) 901 333 753 01 Bracket
  • (4) 901 343 782 00 Bushing
  • (4) 900 075 087 02 Bolt
  • (4) 900 027 015 01 Washer
If you have any questions, feel free to contact APA at 805-955-9699 or "sales at apaindustries dot com"
Tags: 91450125910, 914 501 259 10
Replies(1 - 4)
bdstone914
post Dec 12 2025, 10:27 PM
bdstone914
QUOTE(UROpartsman @ Nov 14 2025, 01:26 PM) *
Rear Kit Contains:
You also need the correct shock bolts.
UROpartsman
post Dec 26 2025, 02:00 PM
QUOTE(bdstone914 @ Dec 12 2025, 08:27 PM) *
(IMG:http://www.914world.com/bbs2/uploads/post-23905-1623631668_thumb.jpg)
Thanks for the tip! Unfortunately the minimum quantity needed to do a production run of Bearing Pin 914 333 565 01 would be more than 80 years of inventory, so we won't be able to make it work.
bdstone914
post Dec 28 2025, 02:10 AM
bdstone914
@Uropartsman
[/quote]
Aftermarket sway bar shock bolts are available from Prekom USA.
Are the weld on brackets for early or late cars?
UROpartsman
post Jan 7 2026, 01:41 PM
Auto Atlanta has them:
https://www.autoatlanta.com/For-your-Porsch...1433356501.html
- Lo-Fi Version Time is now: 31st October 2026 - 09:34 AM
